0.72: Lovelace UI, KIWI Doorlocks, Wireless Tags, Insteon X10.
I am super excited about this release as it brings some great examples of how we are refining the system to become more customizable and, at the same time, user friendly. The first thing that I am really excited about is a new experimental user interface that we call Lovelace. Check this awesome rundown of all the features by @ciotlosm. The TL;DR: a faster, more customizable and more extensible UI with the same look and feel as the old one.
Be aware, this is experimental, so things will change. However, we felt like we didn’t want to keep this away from you any longer. Check the Lovelace UI docs on how to get started. Make sure to share your creations!
Thanks to all the people that have been hanging out in the #beta channel on Discord helping development, finding and squashing bugs and making suggestions. Especially thanks to @c727 for all his development work and @arsaboo for being the first guinea pig.
Example user interface created using Lovelace ([source](https://gist.github.com/ciotlosm/9508388876edf92c4c1f3579e740fbd5#file-ui-lovelace-yaml))
Another change is that Nest, Sonos and Cast will now have to be configured using a config entry. Config entries can be created via the integrations page in the config panel. This is a concept that we have been developing for a couple of months now and it’s our goal to eventually use this as the way to configure all components.
Screenshot of the Nest config entry.
And as if this releases even needs more cool stuff, the Insteon integration now supports X10 thanks to @teharris1. It was a frequent requested feature from the Insteon community.
And finally, we’ll be extending the open beta for Home Assistant Cloud until the first of September.
Enjoy this release and have a good weekend all!
New Platforms
- Weather Platform - IPMA (@dgomes - #14716) (weather.ipma docs) (new-platform)
- Add Freebox device tracker (@stilllman - #12727) (device_tracker.freebox docs) (new-platform)
- Add IBM Watson IoT Platform component (@mtreinish - #13664) (watson_iot docs) (new-platform)
- Wireless tags platform (@sergeymaysak - #13495) (wirelesstag docs) (binary_sensor.wirelesstag docs) (sensor.wirelesstag docs) (switch.wirelesstag docs) (new-platform)
- Add netgear_lte component (@amelchio - #14687) (netgear_lte docs) (notify docs) (sensor.netgear_lte docs) (new-platform)
- Add Uptime Robot sensor (@ludeeus - #14631) (binary_sensor.uptimerobot docs) (new-platform)
- Add support for the Unitymedia Horizon HD Recorder (@benleb - #14275) (media_player.horizon docs) (new-platform)
- Add support for KIWI Door Locks (@c7h - #14485) (lock.kiwi docs) (new-platform)
- Epson projector support (@pszafer - #14841) (media_player.epson docs) (new-platform)
- Add sensor.nsw_fuel_station component (@nickw444 - #14757) (sensor.nsw_fuel_station docs) (new-platform)
- Add support for ZhongHong HVAC Controllers (@crhan - #14552) (climate.zhong_hong docs) (new-platform)
- Xiaomi Cameras - multiple models (@vaidyasr - #14244) (camera.xiaomi docs) (new-platform)
Release 0.72.1 - June 25
- Prevent Nest component setup crash due insufficient permission. (@awarecan - #14966) (nest docs)
- Fix socket bug with Yi in 0.72 (@bachya - #15109) (camera.yi docs)
- Skip nest security state sensor if no Nest Cam exists (@awarecan - #15112) (sensor.nest docs)
- Fix cast config (@balloob - #15143) (media_player.cast docs)
- Bump python-nest to 4.0.3 (@awarecan - #15098) (nest docs) (sensor.nest docs)
Reporting Issues
- For developers of custom panel: Remove ability to register panels directly with the frontend component. Register with custom panel component instead. (@balloob - #14805) (frontend docs) (breaking change)
- Rename Hive hub friendly name to include “Hive” name (@SteveEdson - #14747) (sensor.hive docs) (breaking change)
- Homematic: RotaryHandleSensorIP states will now report open, tilt, closed (@hanzoh - #14885) (sensor.homematic docs) (breaking change)
- Add support for multiple Doorbird stations (@oblogic7 - #13994) (doorbird docs) (camera.doorbird docs) (switch.doorbird docs) (breaking change)
- AirVisual: The radius configuration parameter no longer does anything and has been removed. This won’t negatively impact any existing integrations. Second, this PR will modify the unique IDs for each sensor to correctly include the locale. New unique IDs will now include us and cn (@bachya - #14943) (sensor.airvisual docs) (breaking change)
- Sonos and Cast are now configured via config entries. Go to the integrations tab in config panel to set it up. (@balloob - #14955) (media_player docs) (sonos docs) (media_player.sonos docs) (breaking change)
- Eight Sleep add REM type, Update async syntax, Catch API quirks (@mezz64 - #14937) (eight_sleep docs) (binary_sensor.eight_sleep docs) (sensor.eight_sleep docs) (breaking change)
- Fix energy meter for HS110 v2 users. Not a breaking change unless you are using a custom component (@rytilahti - #15001) (light.tplink docs) (switch.tplink docs) (breaking change) (beta fix)
Beta Fixes
- Remove load power attribute for channel USB (@syssi - #14996) (switch.xiaomi_miio docs) (beta fix)
- Switch to own packaged version of spotipy (@andrey-git - #14997) (media_player.spotify docs) (beta fix)
- Bump pyhs100 version (@rytilahti - #15001) (light.tplink docs) (switch.tplink docs) (breaking change) (beta fix)
- Add experimental UI backend (@balloob - #15002) (frontend docs) (beta fix)
- Fix panel URL authentication for Hass.io (@pvizeli - #15024) (hassio docs) (beta fix)
- Fix linode I/O in state property (@MartinHjelmare - #15010) (binary_sensor.linode docs) (switch.linode docs) (beta fix)
- Upgrade aiohttp to 3.3.2 (@fabaff - #15025) (beta fix)
- Make zone entries work without radius (@balloob - #15032) (zone docs) (beta fix)
- Bugfix empty entity lists (@pvizeli - #15035) (beta fix)
- Rename experimental UI to lovelace (@balloob - #15065) (frontend docs) (beta fix)
- X10 (@teharris1 - #14741) (insteon_plm docs) (switch.insteon_plm docs) (beta fix)
- Fix MQTT Light with RGB and Brightness (@thinkl33t - #15053) (light.mqtt docs) (beta fix)
- Update Neato Library And Reduce Cloud Calls (@dshokouhi - #15072) (neato docs) (camera.neato docs) (switch.neato docs) (vacuum.neato docs) (beta fix)
- Add additional 86sw model identifier of the LAN protocol V2 (@syssi - #14799) (xiaomi_aqara docs) (binary_sensor.xiaomi_aqara docs)
- Allow Kodi live streams to be recognized as paused (@quthla - #14623) (media_player.kodi docs)
- Update syntax (@fabaff - #14812) (sensor.moon docs)
- Use pihole module to get data (@fabaff - #14809) (sensor.pi_hole docs)
- Bump python-miio version (Closes: #13749) (@syssi - #14796) (device_tracker docs) (fan.xiaomi_miio docs) (light.xiaomi_miio docs) (remote.xiaomi_miio docs) (sensor.xiaomi_miio docs) (switch.xiaomi_miio docs) (vacuum.xiaomi_miio docs)
- Further cleanup frontend (@balloob - #14805) (frontend docs) (breaking change)
- netatmo api is now in pip as pyatmo (@jabesq - #14824) (netatmo docs) (binary_sensor.netatmo docs) (camera.netatmo docs) (climate.netatmo docs) (sensor.netatmo docs)
- Action parameter doesn’t longer have to be the first parameter (@GruberMischa - #14815) (binary_sensor.mystrom docs)
- Fixes an issue in Xiaomi TV platform that would some TVs not sleep correctly (@simse - #14829) (media_player.xiaomi_tv docs)
- Improved Fritz!Box thermostat support (@thomaskr - #14789) (climate.fritzbox docs)
- Migrate entity registry to using websocket (@balloob - #14830) (config docs)
- Route themes and translations over websocket (@balloob - #14828) (frontend docs) (websocket_api docs)
- Feature/gearbest library update (Closes: #14813) (@HerrHofrat - #14833)
- Ignore the mistaken long_both_click event of the 86sw (Closes: #14802) (@syssi - #14808) (binary_sensor.xiaomi_aqara docs)
- Fix non awaited test (@balloob - #14854)
- Update Hue flow title (@balloob - #14852) (hue docs)
- Upgrade Mastodon.py to 1.3.0 (@fabaff - #14858)
- Improvements to LIFX reliability (@amelchio - #14848) (light.lifx docs)
- Add general sound mode support (@starkillerOG - #14729) (media_player docs)
- Upgrade aiohttp to 3.3.0 (@fabaff - #14766)
- Add min_temp and max_temp to MQTT climate device (@PhilRW - #14690) (climate.mqtt docs)
- Store config entry id in entity registry (@balloob - #14851)
- Catch ConnectionError (fixes #14241) (@fabaff - #14748) (media_player.yamaha docs)
- Don’t run unnecessary methods in executor pool (@balloob - #14853)
- Fix door/window sensor support of the Xiaomi Aqara LAN protocol V2 (Closes: #14775) (@syssi - #14777) (binary_sensor.xiaomi_aqara docs)
- zha: handle “step_with_on_off” cluster command in LevelListener. (@Adminiuga - #14756) (binary_sensor.zha docs)
- Rename Hive hub friendly name (@SteveEdson - #14747) (sensor.hive docs) (breaking change)
- Add set_default_level to logger (@dale3h - #14703) (logger docs)
- Fix unit conversion (@dgomes - #14730) (climate.generic_thermostat docs) (climate.sensibo docs) (climate.tado docs)
- Disable volume control for Onkyo when unavailable (Closes: #14774) (@snikch - #14863) (media_player.onkyo docs)
- Add support for new hass.io panel (@balloob - #14873) (hassio docs) (panel_custom docs)
- Add color_status sensor for Nest Protect (@awarecan - #14868) (sensor.nest docs)
- UVC camera platform handling unavailable NVR or cameras better (@exxamalte - #14864) (camera.uvc docs)
- Samsung TV can’t turn off after idle period (@ejel - #14587) (media_player.samsungtv docs)
- Discover Qubino ZMHTDx smart meter switches (@turbokongen - #14884) (zwave docs)
- Add missing mapping of RotaryHandleSensorIP states (@hanzoh - #14885) (sensor.homematic docs) (breaking change)
- Add entity registry support to media_player.snapcast (@jedi7 - #14895) (media_player.snapcast docs)
- Allow different identifiers for the CPU temperature (fixes #10104) (@fabaff - #14898) (sensor.glances docs)
- Make RainMachine async (@bachya - #14879) (rainmachine docs) (binary_sensor.rainmachine docs) (sensor.rainmachine docs) (switch.rainmachine docs)
- Upgrade python_opendata_transport to 0.1.3 (@fabaff - #14905) (sensor.swiss_public_transport docs)
- Upgrade psutil to 5.4.6 (@fabaff - #14892) (sensor.systemmonitor docs)
- Upgrade sendgrid to 5.4.0 (@fabaff - #14891) (notify docs)
- Upgrade python-mystrom to 0.4.4 (@fabaff - #14889) (light.mystrom docs) (switch.mystrom docs)
- Upgrade pylast to 2.3.0 (@fabaff - #14888) (sensor.lastfm docs)
- Added daily and hourly modes to Openweathermap (@sgttrs - #14875) (weather.openweathermap docs)
- Bump to denonavr 0.7.3 (@klada - #14907) (media_player.denonavr docs)
- Add api_host option to Konnected config (@heythisisnate - #14896) (konnected docs)
- Update mqtt_eventstream.py (@molobrakos - #14923) (mqtt_eventstream docs)
- Upgrade python-nest, add security_state sensor, nest.set_mode service set ETA as well (@awarecan - #14901) (nest docs) (sensor.nest docs)
- Add more test cases for samsungtv (@ejel - #14900)
- Refactored Arlo component and enhanced Arlo API queries and times (@tchellomello - #14823) (arlo docs) (alarm_control_panel.arlo docs) (camera.arlo docs) (sensor.arlo docs)
- Use cv.time_period instead of cv.time_period_str (@awarecan - #14938) (nest docs)
- Fix snapcast uuid to be more unique (@jedi7 - #14925) (media_player.snapcast docs)
- pytradfri 5.5.1: Improved 3rd party bulb support (@Hate-Usernames - #14887) (tradfri docs) (light.tradfri docs)
- Add scan_interval to RainMachine (@bachya - #14945) (rainmachine docs)
- Myq update from 0.0.8 to 0.0.11 (@arraylabs - #14947) (cover.myq docs)
- Upgrade pylint to 1.9.2 (@scop - #14916)
- Update python-wink to 1.8.0 (@vickyg3 - #14894) (wink docs)
- Add unique_id for mqtt binary sensor (@ciotlosm - #14929) (binary_sensor.mqtt docs)
- Make Yi platform async (@bachya - #14944) (camera.yi docs)
- Nest config flow (@balloob - #14921) (nest docs)
- Fix Facebox face data parsing (@robmarkcole - #14951) (image_processing.facebox docs)
- Make AirVisual platform async + other adjustments (@bachya - #14943) (sensor.airvisual docs) (breaking change)
- Fix tests (@balloob - #14959)
- add relative time option to simulated sensors (@Shou - #14038) (sensor.simulated docs)
- Add config entry for Sonos + Cast (@balloob - #14955) (media_player docs) (sonos docs) (media_player.sonos docs) (breaking change)
- Fix smappee component - “Error on device update” (@bachya - #14883) (sensor.smappee docs)
- Adhere to scan_interval in platforms when setup via config entry (@balloob - #14969)
- Add Calendar API endpoint to get events (@titilambert - #14702) (calendar docs) (calendar.caldav docs)
- Add calendar panel, add tests (@balloob - #14973) (calendar docs)
- Fix binary_sensor.skybell state update when there are no events (@trisk - #14927) (binary_sensor.skybell docs) (sensor.skybell docs)
- Deconz make groups configurable (@Kane610 - #14704) (deconz docs) (light.deconz docs)
- Show notification when user configures Nest client_id/secret (@balloob - #14970) (hue docs) (nest docs)
- Return ISO formated datetime in forecast (@c727 - #14975) (weather.ecobee docs)
- Remove inline pylint disables for messages disabled in pylintrc (@scop - #14978)
- Add availability to Rflink entities. (@aequitas - #14977) (rflink docs)
- Upgrade ring_doorbell to 0.2.1 to fix oauth issues (@tchellomello - #14984) (ring docs)
- Fix extended package support (@cdce8p - #14980)
- Upgraded PyArlo to 0.1.7 (@tchellomello - #14987) (arlo docs)
- Upgraded python-amcrest to 1.2.3 (@tchellomello - #14988) (amcrest docs)
- Upgraded RainCloudy to version 0.0.5 (@tchellomello - #14986) (raincloud docs)
- Do not mount deps folder when running in virtual env (@balloob - #14993)
- Refactoring camera component to use async/await syntax. (@awarecan - #14990) (camera docs)
