Eight Sleep
The eight_sleep
integration allows Home Assistant to fetch data from your Eight Sleep smart cover or mattress.
- Binary Sensor - lets observe the presence state of a Eight Sleep cover/mattress through Home Assistant.
- Sensor - This includes bed state, sleep fitness scores, and results of the current and previous sleep sessions.
It’s setup utilizing ‘Sensor’ platform to convey the current state of your bed and results of your sleep sessions and a ‘Binary Sensor’ platform to indicate your presence in the bed. A service is also provided to set the cooling/heating level and duration of the bed (cooling is only available for the POD mattress).
You must have at least two sleep sessions recorded in the Eight Sleep app prior to setting up the Home Assistant component.
To get started add the following information to your configuration.yaml
file:
eight_sleep:
username: YOUR_E_MAIL_ADDRESS
password: YOUR_PASSWORD
Supported features
Sensors and associated attributes:
- eight_left/right_bed_state
- Attributes:
- Target Heating Level
- Heating Active
- Heating Time Remaining
- Attributes:
- eight left/right_sleep_fitness
- Attributes:
- Fitness Date
- Fitness Duration Score
- Fitness Asleep Score
- Fitness Out-of-Bed Score
- Fitness Wakeup Score
- Attributes:
- eight_left/right_sleep_session
- Attributes:
- Session Start
- Tosses & Turns
- Processing (True/False)
- Time Slept (s)
- Light Sleep %
- Deep Sleep %
- REM Sleep %
- Respiratory Rate
- Heart Rate
- Sleep Stage
- Room Temperature
- Bed Temperature
- Attributes:
- eight_left/right_previous_sleep_session
- Attributes:
- Session Start
- Tosses & Turns
- Time Slept (s)
- Light Sleep %
- Deep Sleep %
- REM Sleep %
- Average Respiratory Rate
- Average Heart Rate
- Average Room Temperature
- Average Bed Temperature
- Attributes:
- eight_left/right_bed_temperature
- eight_left/right_sleep_stage
- eight_room_temperature
Binary Sensors:
- eight_left/right_bed_presence
Service heat_set
You can use the service eight_sleep/heat_set to adjust the target cooling/heating level and heating duration of your bed (cooling is only available for the POD mattress).
Service data attribute | Optional | Description |
entity_id |
no | Entity ID of bed state to adjust. |
target |
no | Target cooling/heating level from -100 to 100. |
duration |
no | Duration to cool/heat at the target level in seconds. |
Script Example:
script:
bed_set_heat:
sequence:
- service: eight_sleep.heat_set
entity_id: "sensor.eight_left_bed_state"
target: 35
duration: 3600
Notice
Please note this component relies on an undocumented API utilized by the Eight Sleep mobile app to communicate with the Eight Sleep servers. It is not supported by Eight Sleep and may malfunction if changes are made to either the mobile app operation or the API format.
