Xiaomi Smart WiFi Socket and Smart Power Strip
The xiaomi_miio switch platform allows you to control the state of your Xiaomi Smart WiFi Socket aka Plug, Xiaomi Smart Power Strip and Xiaomi Chuangmi Plug V1.
Please follow the instructions on Retrieving the Access Token to get the API token to use in the configuration.yaml file.
Features
Supported models: chuangmi.plug.m1, chuangmi.plug.m3, chuangmi.plug.v2, chuangmi.plug.hmi205
  • Power (on, off)
  • Attributes
    • Temperature
Supported models: chuangmi.plug.v1, chuangmi.plug.v3
  • Power (on, off)
  • USB (on, off)
  • Attributes
    • Temperature
Supported models: qmi.powerstrip.v1, zimi.powerstrip.v2
  • Power (on, off)
  • Wifi LED (on, off)
  • Power Price (0…999)
  • Power Mode (green, normal) (Power Strip V1 only)
  • Attributes
    • Temperature
    • Current
    • Load power
    • Wifi LED
    • Mode (Power Strip V1 only)
Xiaomi Air Conditioning Companion V3
Supported models: lumi.acpartner.v3 (the socket of the acpartner.v1 and v2 isn’t switchable!)
  • Power (on, off)
  • Attributes
    • Load power
To add a plug to your installation, add the following to your configuration.yaml file:
# Example configuration.yaml entries
switch:
  - platform: xiaomi_miio
    host: MIIO_IP_ADDRESS
    token: YOUR_TOKEN
host
(string)(Required)
The IP address of your miio device.
token
(string)(Required)
The API token of your miio device.
name
(string)(Optional)
The name of your miio device.
Default value:
Xiaomi Miio Switch
model
(string)(Optional)
The model of your miio device. Valid values are chuangmi.plug.v1, qmi.powerstrip.v1, zimi.powerstrip.v2, chuangmi.plug.m1, chuangmi.plug.m3, chuangmi.plug.v2, chuangmi.plug.v3 and chuangmi.plug.hmi205. This setting can be used to bypass the device model detection and is recommended if your device isn’t always available.
Platform Services
Service xiaomi_miio.switch_set_wifi_led_on (Power Strip only)
Turn the wifi LED on.
Service data attribute Optional Description
entity_id no Only act on a specific Xiaomi miIO switch entity.
Service xiaomi_miio.switch_set_wifi_led_off (Power Strip only)
Turn the wifi LED off.
Service xiaomi_miio.switch_set_power_price (Power Strip)
Set the power price.
price no Power price, between 0 and 999.
Service xiaomi_miio.switch_set_power_mode (Power Strip V1 only)
Set the power mode.
mode no Power mode, valid values are ‘normal’ and ‘green’
