Xiaomi TV
The xiaomi_tv
platform allows you to control a Xiaomi TV.
You need to make sure the TV is connected to the internet, and that your Home Assistant instance is on the same network.
To add a TV to your installation, add the following to your configuration.yaml
file:
media_player:
- platform: xiaomi_tv
When starting or restarting Home Assistant make sure your TV is off. This is a flaw in the TV itself.
If you do not set a host in the configuration file, local TVs will automatically be discovered.
To manually add a TV you can use the following configuration:
media_player:
host: YOUR_TV_IP
The platform will never turn your TV off. Instead, it will be put to sleep and woken up. This can be useful, because the selected source of the TV will remain the same. It will essentially turn your TV into a dumb TV.
