Get floor name: floor_name
The floor_name template function returns the friendly, human-readable name of a floorA floor in Home Assistant is a logical grouping of areas that are meant to match the physical floors in your home. Devices & entities are not assigned to floors but to areas. Floors can be used in automations and scripts as a target for actions. For example, to turn off all the lights on the downstairs floor when you go to bed. [Learn more]. You can give it a floor ID, an areaAn area in Home Assistant is a logical grouping of devices and entities that are meant to match areas (or rooms) in the physical world: your home. For example, the living room area groups devices and entities in your living room. [Learn more] name, an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] ID, or a deviceA device is a model representing a physical or logical unit that contains entities. ID, and it tells you the name of the floor it belongs to.
This is especially useful for building dynamic messages and notificationsYou can use notifications to send messages, pictures, and more, to devices. [Learn more]. Instead of showing a technical floor ID like ground_floor, you can show the actual name “Ground Floor” that you (or whoever receives the message) recognize. For example, when a leak sensor triggers, your notification can say “Water detected on the Ground Floor” by looking up the floor name of the sensorSensors return information about a thing, for instance the level of water in a tank. [Learn more] that triggered.
Usage
{{ floor_name("ground_floor") }}
Ground Floor
Function signature
floor_name(
    lookup_value: str,
) -> str | None
Function parameters
lookup_value string Required
The floor ID, area name, entity ID, or device ID to look up. Returns the friendly name of the floor, or None if no matching floor is found.
Good to know
  • Returns None when the lookup value does not match a floor.
  • The name changes when you rename the floor, so the output can shift over time.
Try it yourself
More examples
Get the floor name from an entity
Find out which floor a sensor is on by passing its entity ID.
{{ floor_name("sensor.living_room_temperature") }}
Ground Floor
Use in a notification with the trigger floor
A common pattern: when a sensor triggers an automationAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more], include the floor name in the notification. This works with any triggerA trigger is a set of values or conditions of a platform that are defined to cause an automation to run. [Learn more] that provides trigger.entity_id, such as state or leak triggers.
action:
  - action: notify.mobile
      title: >
        {{ floor_name(trigger.entity_id) }}
      message: >
        Alert on {{ floor_name(trigger.entity_id) }}
List all floor names
Loop through all floors and display their names.
{% for id in floors() %}
  {{ floor_name(id) }}
{% endfor %}
Ground Floor
First Floor
Basement
Show the floor of each area
Build a summary showing which floor each area belongs to, using floor_name as a way to resolve the human-readable floor for each area.
{% for id in areas() %}
  {{ area_name(id) }}: {{ floor_name(id) }}
{% endfor %}
Living Room: Ground Floor
Kitchen: Ground Floor
Bedroom: First Floor
Still stuck?
Tip
Related template functions
