Test entity state: is_state
The is_state template function tests if an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] is in a specific state. It returns true or false. This is probably the template function you’ll use most often, and it’s the recommended way to check what state something is in.
Whenever you need to make a decision based on the current state of a deviceA device is a model representing a physical or logical unit that contains entities. or sensorSensors return information about a thing, for instance the level of water in a tank. [Learn more], is_state is the way to do it. Is the alarm armed? Is someone home? Is a door open? Is the washing machine still running? These are all yes/no questions about the state of an entity, and is_state answers them. It’s also safer than comparing states directly, because it will never throw an error if the entity doesn’t exist yet (for example, during Home Assistant startup). It returns false.
Tip
Automation conditions and triggers already let you check an entity’s state through the visual editor, no template needed. Reach for is_state() when you need the result inside a template expression, notification message, or template sensor.
Usage
{{ is_state("device_tracker.phone", "home") }}
true
Function signature
is_state(
    entity_id: str,
    state: str | list[str],
) -> bool
Function parameters
entity_id string Required
The entity ID to check.
state string | list Required
The state value to compare against. Can be a single string or a list of strings to match against any of them.
Checking against multiple states
You can pass a list of states to check against. The function returns true if the entity’s state matches any value in the list.
{{ is_state("vacuum.roborock", ["cleaning", "returning"]) }}
true
Good to know
  • Returns false (not an error) when the entity does not exist, making it safer than string comparison during startup.
  • The state to compare against is always a string. Numeric states need to be wrapped in quotes, like is_state("sensor.x", "25").
  • Passing a list of states returns true if any of them match, acting like an OR check.
Try it yourself
More examples
Use in an automation conditionConditions are an optional part of an automation that will prevent an action from firing if they are not met. [Learn more]
Only run the rest of the automationAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more] if the alarm is armed away.
condition:
  - condition: template
    value_template: >
      {{ is_state("alarm_control_panel.home", "armed_away") }}
Combine with iif in a notification
Send a notificationYou can use notifications to send messages, pictures, and more, to devices. [Learn more] that includes the current state of the front door, using iif to convert the state into a human-readable word.
action:
  - action: notify.mobile
      message: >
        The front door is
          iif(is_state("binary_sensor.front_door", "on"),
          "open", "closed")
Still stuck?
Tip
Related template functions
