Get area name: area_name
The area_name template function returns the friendly, human-readable name of an areaAn area in Home Assistant is a logical grouping of devices and entities that are meant to match areas (or rooms) in the physical world: your home. For example, the living room area groups devices and entities in your living room. [Learn more]. You can give it an area ID, an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] ID, or a deviceA device is a model representing a physical or logical unit that contains entities. ID, and it tells you the name of the area it belongs to.
This is especially useful for building dynamic messages and notificationsYou can use notifications to send messages, pictures, and more, to devices. [Learn more]. Instead of showing a technical area ID like living_room, you can show the actual name “Living Room” that you (or whoever receives the message) recognize. For example, when motion is detected, your notification can say “Motion detected in the Living Room” by looking up the area name of the sensorSensors return information about a thing, for instance the level of water in a tank. [Learn more] that triggered.
Usage
{{ area_name("living_room") }}
Living Room
Function signature
area_name(
lookup_value: str,
) -> str | None
Function parameters
Good to know
- Returns
Nonewhen the lookup value does not match an area, entity, or device. - When an entity or device has no area assigned, the result is
None. - The name reflects the current area label, so renaming an area updates the output immediately.
Try it yourself
More examples
Get the area name from an entity
Find out which room a sensor is in by passing its entity ID.
{{ area_name("sensor.living_room_temperature") }}
Living Room
Use in a notification with the trigger area
A very common pattern: when a sensor triggers an automationAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more], include the room name in the notification. This works with any triggerA trigger is a set of values or conditions of a platform that are defined to cause an automation to run. [Learn more] that provides trigger.entity_id, such as state or motion triggers.
action:
- action: notify.mobile
title: >
{{ area_name(trigger.entity_id) }}
message: >
Motion detected in {{ area_name(trigger.entity_id) }}
List all area names
Loop through all areas and display their names.
{% for area_id in areas() %}
{{ area_name(area_id) }}
{% endfor %}
Living Room
Kitchen
Bedroom
Hallway
List rooms with open windows
A common use case: build a message listing which rooms have open windows or doors. This uses area_name as a filter to convert each open sensor’s entity ID into a room name, then removes duplicates.
states.binary_sensor
| selectattr('attributes.device_class', 'in',
('window', 'door'))
| map(attribute='entity_id')
| select('is_state', 'on')
| map('area_name')
| select
| unique
| list
| join(', ')
Kitchen, Bedroom
Still stuck?
Related template functions
Get area ID: area_id - Returns the area ID for a given area name, entity ID, or device ID.
Get entities in an area: area_entities - Returns a list of entity IDs associated with a given area.
Get devices in an area: area_devices - Returns a list of device IDs associated with a given area.
Get all areas: areas - Returns a list of all area IDs in your Home Assistant instance.
