Get entities in an area: area_entities
The area_entities template function returns a list of entity IDs that belong to a given areaAn area in Home Assistant is a logical grouping of devices and entities that are meant to match areas (or rooms) in the physical world: your home. For example, the living room area groups devices and entities in your living room. [Learn more]. You can specify the area by its name (like “Living Room”) or by its internal ID. It gives you all entitiesAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] that have been assigned to that area in Home Assistant.
This is useful when you want to work with all entities in a room at once, without having to list each one by hand. For example, you could turn off every light in the bedroom at bedtime, check if any window in the house is open, or count how many motion sensors are currently active on a floorA floor in Home Assistant is a logical grouping of areas that are meant to match the physical floors in your home. Devices & entities are not assigned to floors but to areas. Floors can be used in automations and scripts as a target for actions. For example, to turn off all the lights on the downstairs floor when you go to bed. [Learn more]. As you add or remove devicesA device is a model representing a physical or logical unit that contains entities. from an area in Home Assistant, the list automatically updates, so your automationsAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more] and templatesA template is an automation definition that can include variables for the action or data from the trigger values. This allows automations to generate dynamic actions. [Learn more] always stay in sync with your actual setup.
Tip
Automation actions can target an entire area through the visual editor, no template needed. Reach for area_entities() when you need to loop over or filter the entities inside a template expression.
Usage
{{ area_entities("Living Room") }}
  "light.living_room_ceiling",
  "sensor.living_room_temperature",
  "binary_sensor.living_room_motion",
Function signature
area_entities(
    area_name_or_id: str,
) -> list[str]
Function parameters
area_name_or_id string Required
The name or ID of the area. You can find area IDs in Settings > Areas, labels & zones.
Good to know
  • Returns an empty list when the area has no entities or when the name does not match. It does not raise an error.
  • Includes both entities assigned directly to the area and entities inherited from devices in that area.
  • The names used in the lookup are case-sensitive, so "Living Room" and "living room" are not the same.
Try it yourself
More examples
Count the lights that are on in an area
Want to know how many lights are currently on in a room? This combines area_entities with filters to narrow down to lights and count the ones that are on.
  area_entities("Kitchen")
  | select("match", "light.")
  | select("is_state", "on")
  | list
  | count
Result (integerA whole number without decimal places, like 1, 42, or -5. Used for counts, indices, and whole values.)
3
Check if any motion sensor is active in an area
This checks whether any motion sensor in the hallway is currently detecting motion. Useful as a conditionConditions are an optional part of an automation that will prevent an action from firing if they are not met. [Learn more] in automations.
  area_entities("Hallway")
  | select("match", "binary_sensor.")
  | list
  | count > 0
true
Still stuck?
Tip
Related template functions
