Media player
The Media player integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the media player entities in Home Assistant, such as TVs, speakers, and receivers. Other integrations create these entities, for example, Sonos or Google Cast. You can control your media players from your dashboards, and use them in automations.
Building block integration
This media player is a building block integration that cannot be added to your Home Assistant directly but is used and provided by other integrations.
A building block integration differs from the typical integration that connects to a device or service. Instead, other integrations that do integrate a device or service into Home Assistant use this media player building block to provide entities, services, and other functionality that you can use in your automations or dashboards.
If one of your integrations features this building block, this page documents the functionality the media player building block offers.
Media player states
A media player can have the following states. Each item shows the label you see in the Home Assistant interface, followed by the state as Home Assistant stores it. If you write templates or edit automations in YAML, use the stored state.
Off (
off): The media player is turned off and is not accepting commands until turned on. -
On (
on): The media player is turned on, but no details on its state are currently known. -
Idle (
idle): The media player is turned on and accepting commands, but not playing any media. For example, it might show a home screen. -
Playing (
playing): The media player is currently playing media. -
Paused (
paused): The media player has media loaded and is paused. -
Buffering (
buffering): The media player is preparing to start playback of media. -
Unavailable (
unavailable): The entity is currently unavailable. -
Unknown (
unknown): The state is not yet known.
Playing media from the media browser
You can browse your media in the media browser, and play it on a media player, such as a speaker or a TV. To choose the media player, open the list of players in the bottom-right corner of the media browser. The list only shows media players that support browsing media.
- For the steps, refer to Browsing your media.
- If a media player is missing from the list or grayed out, refer to Troubleshooting.
List of triggers
The Media player integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following triggers. Each link below opens a dedicated page with examples, fields, and a step-by-step UI walkthrough.
Media player muted (
media_player.muted) Triggers when one or more media players are muted. -
Media player paused playing (
media_player.paused_playing) Triggers when one or more media players pause playing. -
Media player started playing (
media_player.started_playing) Triggers when one or more media players start playing. -
Media player stopped playing (
media_player.stopped_playing) Triggers when one or more media players stop playing. -
Media player turned off (
media_player.turned_off) Triggers when one or more media players turn off. -
Media player turned on (
media_player.turned_on) Triggers when one or more media players turn on. -
Media player unmuted (
media_player.unmuted) Triggers when one or more media players are unmuted. -
Media player volume changed (
media_player.volume_changed) Triggers when the volume of one or more media players changes. -
Media player volume crossed threshold (
media_player.volume_crossed_threshold) Triggers when the volume of one or more media players crosses a threshold.
For an overview of every trigger across all integrations, see the triggers reference.
List of conditions
The Media player integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following conditions. Each link below opens a dedicated page with examples, fields, and a step-by-step UI walkthrough.
Media player current source (
media_player.is_current_source) Tests if one or more media players are set to a specific source. -
Media player is muted (
media_player.is_muted) Tests if one or more media players are muted. -
Media player is not playing (
media_player.is_not_playing) Tests if one or more media players are not playing. -
Media player is off (
media_player.is_off) Tests if one or more media players are off. -
Media player is on (
media_player.is_on) Tests if one or more media players are on. -
Media player is paused (
media_player.is_paused) Tests if one or more media players are paused. -
Media player is playing (
media_player.is_playing) Tests if one or more media players are playing. -
Media player is not muted (
media_player.is_unmuted) Tests if one or more media players are not muted. -
Media player volume (
media_player.is_volume) Tests the volume of one or more media players.
For an overview of every condition across all integrations, see the conditions reference.
List of actions
The Media player integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following actions. Each link below opens a dedicated page with examples, parameters, and a step-by-step UI walkthrough.
Browse media (
media_player.browse_media) Browses the media available on a media player. -
Clear media player playlist (
media_player.clear_playlist) Removes all items from a media player’s playlist. -
Join media players (
media_player.join) Groups media players together for synchronous playback. -
Next track (
media_player.media_next_track) Selects the next track on a media player. -
Pause media (
media_player.media_pause) Pauses playback on a media player. -
Play media (
media_player.media_play) Starts playback on a media player. -
Play/Pause media (
media_player.media_play_pause) Toggles play and pause on a media player. -
Previous track (
media_player.media_previous_track) Selects the previous track on a media player. -
Seek media (
media_player.media_seek) Jumps to a different position in the media currently playing. -
Stop media (
media_player.media_stop) Stops playback on a media player. -
Play specified media (
media_player.play_media) Plays specific media on a media player. -
Set media player repeat (
media_player.repeat_set) Sets the repeat mode of a media player. -
Search media (
media_player.search_media) Searches the media available on a media player. -
Select media player sound mode (
media_player.select_sound_mode) Selects a sound mode of a media player. -
Select media player source (
media_player.select_source) Changes the input source of a media player. -
Set media player shuffle (
media_player.shuffle_set) Enables or disables shuffle mode on a media player. -
Toggle media player (
media_player.toggle) Toggles a media player on or off. -
Turn off media player (
media_player.turn_off) Turns off a media player. -
Turn on media player (
media_player.turn_on) Turns on a media player. -
Unjoin media player (
media_player.unjoin) Removes a media player from a group. -
Turn down media player volume (
media_player.volume_down) Turns down the volume of a media player. -
Mute/unmute media player (
media_player.volume_mute) Mutes or unmutes a media player. -
Set media player volume (
media_player.volume_set) Sets the volume level of a media player. -
Turn up media player volume (
media_player.volume_up) Turns up the volume of a media player.
Media player automation examples
Here are a few examples of how you can use Media player triggers and conditions in automations.
Automation: dim the room when a movie starts
When the living room TV starts playing, dim the lights so the room is ready for watching.
Trigger: Media player started playing
- Target: Living room TV
Action: Turn on light
- Target: Living room lights
- Brightness: 25%
YAML example for dimming the room when a movie starts
alias: "Dim the room when the TV starts playing"
triggers:
- trigger: media_player.started_playing
entity_id: media_player.living_room_tv
actions:
- action: light.turn_on
entity_id: light.living_room_lights
brightness_pct: 25
Automation: send a bedtime reminder if audio is still playing
At bedtime, check whether the bedroom speaker is still playing, and send a notification if it is.
- Trigger: Time: 23:00
Condition: Media player is playing
- Target: Bedroom speaker
Action: Send a notification message
Target: My Device (
notify.my_device)
Target: My Device (
YAML example for a bedtime playback reminder
alias: "Remind me when audio is still playing at bedtime"
triggers:
- trigger: time
at: "23:00:00"
conditions:
- condition: media_player.is_playing
entity_id: media_player.bedroom_speaker
actions:
- action: notify.send_message
entity_id: notify.my_device
message: >
Bedroom audio is still playing.
Device class
The device class tells Home Assistant what kind of media player an entity is, such as a TV or a speaker. Home Assistant uses the device class to choose the icon. Google Assistant, Alexa, and Apple Home use the device class to decide what kind of device to show.
The integration that provides the media player sets the device class.
Device classes in automations and templates
- Automations: The device class doesn’t change how a media player works in automations.
- Templates: The device class is the
device_classattribute of the entity. Use the stored value, such astv. For example, you can find entities by device class.
List of available device classes
A media player without a device class is a generic media player and shows
Each item shows the name you see in the Home Assistant interface, followed by the device class as Home Assistant stores it.
TV ( tv): A television. -
Speaker ( speaker): A speaker. -
Receiver ( receiver): A device that takes audio and video input and outputs it to speakers and displays. -
Projector ( projector): A projector.
