HP Printer
The HP Printer integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] connects Home Assistant to HP printers on your local network.
It reads the information the printer publishes through its built-in web server: the printer status, the ink or toner levels, and the page counters for printing, scanning, copying, and faxing. No cloud account is needed.
Use cases
  • Get notified when an ink or toner cartridge is running low, so you can order a replacement in time.
  • Get notified when the paper tray is empty.
  • Track how many pages you print, scan, and copy over time, for example to compare color and black and white usage.
Supported devices
The integration works with HP printers that have a built-in web server (the page that opens when you enter the printer’s IP address in a browser) and report their data through it.
The following printers are known to work:
  • HP Color LaserJet M255dw
  • HP ENVY Photo 7830 All-in-One
  • HP OfficeJet Pro 9022e
Which sensors are created depends on the printer model. For example, a printer without a scanner or fax does not get the scanner or fax sensors.
Unsupported devices
The following devices are not supported:
  • Printers that are only connected over USB, without a network connection.
  • Printers whose built-in web server only answers over HTTPS.
  • Printers that do not report a serial number.
  1. Connect the printer to your network.
  2. Find the printer’s IP address. You can usually print it from the printer’s control panel, for example in the network settings or by printing a network configuration page.
  3. Optional, but recommended: in your router, give the printer a fixed IP address, so it does not change after a restart.
  4. Check that the printer’s built-in web server is reachable: in a browser, open http://<printer IP address>/DevMgmt/ProductConfigDyn.xml and http://<printer IP address>/DevMgmt/ProductStatusDyn.xml, replacing <printer IP address> with your printer’s IP address. The browser should show an XML document for both.
To add the HP Printer device to your Home Assistant instance, use this My button:
  • From the list, select HP Printer.
Host
The IP address or hostname of your printer. For example, 192.168.1.12.
Supported functionality
Each printer is added as a device in Home Assistant, with the following entities. Some entities are disabled by default. To use them, enable them first.
Sensors
  • Status
    • Description: What the printer is currently doing.
    • Values: Canceling job, Copying, Power save, Off, Printing, Ready, Scanning, Paper tray empty.
    • Remarks: If the printer reports a status that is not in this list, the sensor shows as unknown.
  • Cyan level, Magenta level, Yellow level, Black level, Tri-color level
    • Description: Estimated ink or toner remaining in the cartridge as a percentage.
    • Remarks: One sensor is created for each cartridge the printer reports. Tri-color is used for combined cyan, magenta, and yellow cartridges. While a cartridge is removed, its sensors show as unavailable.
  • Cyan pages remaining, Magenta pages remaining, Yellow pages remaining, Black pages remaining, Tri-color pages remaining
    • Description: Estimated number of pages the cartridge can still print.
    • Remarks: Only created when the printer reports this estimate. Many inkjet printers don’t.
  • Printed pages
    • Description: Total number of pages printed.
  • Printed black and white pages
    • Description: Number of pages printed in black and white.
  • Printed color pages
    • Description: Number of pages printed in color.
  • Printed single-sided sheets
    • Description: Number of sheets printed on one side.
    • Remarks: Disabled by default.
  • Printed double-sided sheets
    • Description: Number of sheets printed on both sides.
  • Paper jams
    • Description: Number of paper jams while printing. Shown as diagnostic information on the device page.
  • Paper mispicks
    • Description: Number of times the printer failed to pick up a sheet of paper. Shown as diagnostic information on the device page.
  • Scanned pages
    • Description: Total number of pages scanned.
  • Scanned pages from document feeder
    • Description: Number of pages scanned from the automatic document feeder.
  • Scanned pages from glass
    • Description: Number of pages scanned from the scanner glass.
  • Scanned double-sided sheets
    • Description: Number of sheets scanned on both sides.
  • Scanner jams
    • Description: Number of paper jams in the document feeder. Shown as diagnostic information on the device page.
  • Scanner mispicks
    • Description: Number of times the document feeder failed to pick up a sheet of paper. Shown as diagnostic information on the device page.
  • Copied pages
    • Description: Total number of pages copied.
  • Faxed pages
    • Description: Total number of pages faxed.
HP Printer automation examples
The sensors of this integration are a good basis for supply and maintenance automations. Here are a few ideas to get you started.
Tip
Automation: Notify when the ink is running low
Send a notification to your phone when the black cartridge drops below 10%, so you can order a new one in time.
  • Trigger: Numeric state
    • Entity: Black level (sensor.office_printer_black_level)
    • Below: 10
  • Action: Send a notification message
    • Target: My Device (notify.my_device)
YAML example for notifying when the ink is running low
alias: "Notify when the printer ink is running low"
triggers:
  - trigger: numeric_state
    entity_id: sensor.office_printer_black_level
    below: 10
actions:
  - action: notify.send_message
      entity_id: notify.my_device
      message: >
        The black cartridge of the printer is at
        {{ states('sensor.office_printer_black_level') }}%.
Automation: Notify when the paper tray is empty
Send a notification to your phone when the printer runs out of paper.
  • Trigger: State
    • Entity: Status (sensor.office_printer_status)
    • To: Paper tray empty
YAML example for notifying when the paper tray is empty
alias: "Notify when the printer paper tray is empty"
triggers:
  - trigger: state
    entity_id: sensor.office_printer_status
    to: "tray_empty"
actions:
      message: "The printer is out of paper."
Data updates
The HP Printer integration pollsData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] the printer every minute.
When the printer is switched off or cannot be reached, its entities become unavailable. They recover on the next update after the printer is back online.
Known limitations
  • The integration is read-only. It cannot manage print jobs or change printer settings.
  • The integration connects over HTTP on port 80. Printers that only accept HTTPS are not supported.
  • Printheads are not shown as consumables.
  • If the printer’s IP address changes, remove the integration and add it again with the new address.
Can’t set up the printer
Symptom: “Failed to connect” during setup
When trying to set up the integration, the form shows a message that it failed to connect.
Description
Home Assistant could not read the printer’s information from its built-in web server.
Resolution
  1. Make sure the printer is switched on and connected to the network.
  2. In a browser, open http://<printer IP address>/DevMgmt/ProductConfigDyn.xml and http://<printer IP address>/DevMgmt/ProductStatusDyn.xml, replacing <printer IP address> with your printer’s IP address.
    • If the pages do not load, check the IP address and make sure Home Assistant and the printer are on the same network.
    • If either page loads but shows no XML document, your printer model is not supported.
Entities are unavailable
Symptom: All the printer’s entities show as unavailable
Description
The printer did not respond to the last update. This is expected while the printer is switched off. Some printers also stop responding when they go into a deep sleep mode.
Resolution
  1. Switch on the printer. The entities recover within a minute.
  2. If the printer has an auto-off or deep sleep setting, consider changing it in the printer’s settings.
  3. If the printer’s IP address has changed, remove the integration and add it again with the new address.
      • Devices
      • Hubs
      • Services
      • Integration entries
  3. To confirm, select Delete.
