HAVEN IAQ
The HAVEN IAQ integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] connects supported HAVEN IAQ air quality monitors to Home Assistant over your local network. Depending on the device, the integration provides indoor air quality and airflow measurements.
Supported devices
The integration supports the following HAVEN IAQ products:
  • Room Air Monitor
  • Central Air Monitor
  • Connect the HAVEN IAQ device and Home Assistant to the same local network.
  • Install firmware that supports the HAVEN local API:
    • Room Air Monitor: firmware 19 or later.
    • Central Air Monitor: firmware 2.4.2 or later.
  • In the HAVEN app, enable Home Assistant for each device. This enables the device’s local HTTP API, which is disabled by default.
Home Assistant discovers compatible devices automatically. If a device is not discovered, you can add it manually by entering its hostname or IP address.
To add the HAVEN IAQ device to your Home Assistant instance, use this My button:
HAVEN IAQ can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
  • From the list, select HAVEN IAQ.
Host
The hostname or IP address of the HAVEN IAQ device.
Supported functionality
Particle count sensors are disabled by default for both models. You can enable them if you want particle count measurements.
Room Air Monitor
The Room Air Monitor provides these measurements:
  • Temperature
  • Humidity
  • Dew point
  • Carbon dioxide
  • Total volatile organic compounds index
  • Nitrogen oxides index
  • PM1.0, PM2.5, PM4.0, and PM10 mass concentration
  • PM0.5, PM1.0, PM2.5, PM4.0, and PM10 particle count
Central Air Monitor
The Central Air Monitor provides these measurements:
  • Temperature
  • Humidity
  • Pressure
  • Carbon dioxide
  • Total volatile organic compounds concentration
  • PM2.5 and PM10 mass concentration
  • PM2.5 and PM10 particle count
  • Airflow
  • Airflow duration
Data updates
This integration uses local pollingData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more]. Home Assistant requests updated data from the device once per minute.
Known limitations
  • Communication uses unencrypted HTTP on the local network. Do not expose the device’s HTTP port to the internet.
The device is not discovered
  1. Confirm that Home Assistant and the HAVEN IAQ device are connected to the same local network.
  2. Confirm that Home Assistant is enabled for the device in the HAVEN app.
  3. Confirm that the device runs a supported firmware version.
  4. Add the integration manually and enter the device’s hostname or IP address.
Entities are unavailable
  1. Confirm that the HAVEN IAQ device is powered on and connected to Wi-Fi.
  2. Confirm that Home Assistant remains enabled for the device in the HAVEN app.
  3. Confirm that Home Assistant can still reach the device at its configured hostname or IP address.
  4. If a manually entered IP address changed and the device is not rediscovered automatically, remove and add the integration again using the new address.
      • Devices
      • Hubs
      • Services
      • Integration entries
  3. To confirm, select Delete.
