Today at a specific time: today_at
The today_at template function returns a datetimeA value representing a specific moment in time, including the date, time, and time zone. For example, 2026-04-05 14:30:00+00:00. Used for timestamps, scheduling, and time-based calculations. object for today’s date at a specific time you provide. Give it a time string like “08:00” or “14:30:00” and it returns a full datetime representing that time today, in your local time zone.
This is especially useful in automationsAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more] when you need to check whether the current time is before or after a specific point in the day. For example, you might want to turn on lights only after 18:00, send a morning summary at 07:00, or check if it is still before bedtime. Instead of manually constructing a datetime from the current date and your target time, today_at handles it in a single call.
Usage
{{ today_at("08:00") }}
2024-03-15 08:00:00+01:00
Function signature
today_at(time_str: str = "00:00") -> datetime
Function parameters
Comparing with the current time
A common use is to check if the current time is before or after a specific point in the day, using now for comparison.
{{ now() > today_at("18:00") }}
false
Good to know
- The returned datetime is in your Home Assistant time zone, making it safe to compare directly with
now. - “Today” is determined when the template runs, so a template scheduled at 23:59 and compared at 00:01 will use two different dates.
- Accepts strings in
"HH:MM"or"HH:MM:SS"format. Other formats raise an error.
Try it yourself
More examples
Only run an automation in the evening
Use today_at in a conditionConditions are an optional part of an automation that will prevent an action from firing if they are not met. [Learn more] to limit an automationAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more] to run only between 18:00 and 23:00.
condition:
- condition: template
value_template: >
{{ today_at("18:00") <= now() < today_at("23:00") }}
Calculate minutes until a time
Find out how many minutes remain until a specific time today.
{{ ((today_at("17:00") - now()).total_seconds() / 60) | int }}
150
Set a time-based brightness
Adjust light brightness based on how close it is to bedtime.
{% set bedtime = today_at("22:00") %}
{% set hours_left = ((bedtime - now()).total_seconds() / 3600)
| float | round(1) %}
{{ [((hours_left / 4) * 100) | int, 10] | max }}
75
Still stuck?
Related template functions
Current local date and time: now - Returns the current date and time in your local time zone.
Convert to datetime: as_datetime - Converts a string or timestamp to a datetime object.
Convert to UNIX timestamp: as_timestamp - Converts a datetime object or string to a UNIX timestamp.
Create a time duration: timedelta - Creates a timedelta object from numeric time components.
