Format timestamp as UTC time: timestamp_utc
The timestamp_utc filter formats a UNIX timestamp as a datetime string in UTC (Coordinated Universal Time). It returns the date and time in the standard ISO-like format, without any local time zone conversion.
This is useful when you need to display or log times in UTC, share timestamps with external services that expect UTC, or compare times across different time zones without ambiguity. If you want the local time representation instead, use timestamp_local. If you need a custom format, use timestamp_custom with the local_time parameter set to false.
Usage
As a filter
{{ 1710510600 | timestamp_utc }}
2024-03-15 13:30:00+00:00
Function signature
value | timestamp_utc(
    default: Any = None,
) -> str | Any
Function parameters
default any (Optional)
Value to return if the formatting fails. If not provided, an error is raised on invalid input.
Using a default value
If the input might not be a valid timestamp, provide a default to avoid errors.
{{ "invalid" | float(0) | timestamp_utc(default="unknown") }}
unknown
Good to know
  • The input must be a UNIX timestamp (a number of seconds). Pass a datetime object through as_timestamp first.
  • The result is a string, not a datetime object.
  • Without a default, the filter raises an error for non-numeric inputs.
Try it yourself
More examples
Display a sensor timestamp in UTC
Convert the last changed timestamp of an entity to a UTC datetime string.
{{ as_timestamp(states.sensor.temperature.last_changed) | timestamp_utc }}
Compare local and UTC representations
Display the same timestamp in both local and UTC format to see the difference.
{% set ts = as_timestamp(now()) %}
Local: {{ ts | timestamp_local }}
UTC: {{ ts | timestamp_utc }}
Local: 2024-03-15 14:30:00+01:00
UTC: 2024-03-15 13:30:00+00:00
Log an event time in UTC
Use UTC timestamps in automationsAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more] for consistent logging regardless of time zone.
action:
  - action: notify.log
      message: >
        Event occurred at
        {{ as_timestamp(now()) | timestamp_utc }}
Still stuck?
Tip
Related template functions
