Format timestamp as local time: timestamp_local
The timestamp_local filter formats a UNIX timestamp as a datetime string in your local time zone. It returns the date and time in the standard ISO-like format, automatically converting from UTC to the time zone configured in Home Assistant.
This is a quick way to turn a UNIX timestamp into a readable local date and time without needing to specify a format string. If you need a custom format, use timestamp_custom instead. If you want the UTC representation, use timestamp_utc. This filter is particularly useful for displaying sensor attributes or API responses that provide times as UNIX timestamps.
Usage
{{ 1710510600 | timestamp_local }}
2024-03-15 14:30:00+01:00
Function signature
value | timestamp_local(
default: Any = None,
) -> str | Any
Function parameters
Using a default value
If the input might not be a valid timestamp, provide a default to avoid errors.
{{ "invalid" | float(0) | timestamp_local(default="unknown") }}
unknown
Good to know
- The input must be a UNIX timestamp (a number of seconds). Pass a datetime object through
as_timestampfirst. - The result is a string, not a datetime object. To do datetime math, use
as_localinstead. - Without a
default, the filter raises an error for non-numeric inputs.
Try it yourself
More examples
Display a sensor’s last changed time
Convert the last changed timestamp of an entity to a readable local time string.
{{ as_timestamp(states.sensor.temperature.last_changed) | timestamp_local }}
Show the current time as a formatted string
Convert the current UNIX timestamp to a local datetime string.
{{ as_timestamp(now()) | timestamp_local }}
Use in a notification
Include a formatted local timestamp in a notificationYou can use notifications to send messages, pictures, and more, to devices. [Learn more] message.
action:
- action: notify.mobile
message: >
Motion detected at
as_timestamp(states.binary_sensor.motion.last_changed)
| timestamp_local
Still stuck?
Related template functions
Format timestamp as UTC time: timestamp_utc - Formats a UNIX timestamp as a UTC datetime string.
Format timestamp with custom format: timestamp_custom - Formats a UNIX timestamp as a string using a custom format.
Convert to UNIX timestamp: as_timestamp - Converts a datetime object or string to a UNIX timestamp.
Convert to local time zone: as_local - Converts a datetime object to your local time zone.
