Human-readable time elapsed: time_since
The time_since template function returns a human-readable string describing how much time has elapsed since a given datetimeA value representing a specific moment in time, including the date, time, and time zone. For example, 2026-04-05 14:30:00+00:00. Used for timestamps, scheduling, and time-based calculations.. Give it a datetime in the past, and it returns something like “2 hours” or “3 days and 5 hours” instead of a raw number of seconds.
This is useful whenever you want to display elapsed time in a natural, readable format. For example, showing “last seen 45 minutes ago” on a dashboard, displaying how long a door has been open, or reporting how long ago a sensor last updated. The function only works with datetimes in the past. For future datetimes, use time_until instead. You can control the level of detail with the optional precision parameter, which determines how many time components (years, months, days, hours, minutes, seconds) to include.
Usage
{{ time_since(states.binary_sensor.front_door.last_changed) }}
2 hours
Function signature
time_since(
    value: datetime,
    precision: int = 1,
) -> str
Function parameters
value datetime Required
A datetime object representing a point in the past. The function calculates the time elapsed between this datetime and now.
precision integer (Optional, default: 1)
The number of time components to include in the output, from 1 to 6. A precision of 1 might return “2 hours”, while a precision of 2 might return “2 hours and 30 minutes”. Higher precision gives more detail.
Controlling precision
By default, time_since returns only the largest time component. Increase the precision to include more detail.
{{ time_since(states.binary_sensor.front_door.last_changed, 1) }}
2 hours
{{ time_since(states.binary_sensor.front_door.last_changed, 3) }}
2 hours, 30 minutes and 15 seconds
Good to know
  • Only works with datetimes in the past. For future datetimes, use time_until instead.
  • Durations shorter than one second return "0 seconds".
  • The input datetime must be time zone aware. Pass something like states.sensor.foo.last_changed or now(), not a naive datetime.
Try it yourself
More examples
Show how long a door has been open
Display the elapsed time since a door opened on your dashboard.
  "Open for "
  ~ time_since(states.binary_sensor.front_door.last_changed)
Open for 2 hours
Detailed elapsed time in a notification
Send a notificationYou can use notifications to send messages, pictures, and more, to devices. [Learn more] with a more detailed breakdown of elapsed time.
action:
  - action: notify.mobile
      message: >
        The washing machine has been running for
        {{ time_since(states.sensor.washer_start.last_changed, 2) }}.
Show when something was last seen
Create a “last seen” display for a person tracker.
  "Last seen "
  ~ time_since(states.person.paulus.last_changed) ~ " ago"
Last seen 45 minutes ago
Still stuck?
Tip
Related template functions
