Get state attribute: state_attr
The state_attr template function returns the value of a specific attribute from an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more]‘s state. Entities in Home Assistant often have more information than their main state. For example, a climate entity’s state might be heating, but it also has attributes like temperature, current_temperature, and hvac_modes.
You’ll use this whenever you need information beyond the main state of an entity. Common examples include reading the brightness of a light, the battery level of a deviceA device is a model representing a physical or logical unit that contains entities., the friendly name of an entity, or the list of options available on a select entity. If the entity or attribute doesn’t exist, it returns None instead of causing an error.
Tip
For dashboards, a Tile card can show attributes as badges without a template. Reach for state_attr() when you need the value inside an automation, a notification message, or another template.
Usage
{{ state_attr("climate.living_room", "temperature") }}
Result (floatA number that can have decimal places, like 21.5 or 3.14. Used for temperatures, percentages, and other measurements that need precision.)
21.0
Function signature
state_attr(
    entity_id: str,
    attribute: str,
) -> Any
Function parameters
entity_id string Required
The entity ID to get the attribute from.
attribute string Required
The name of the attribute to retrieve. Returns None if the entity or attribute does not exist.
Tip
To see all available attributes for an entity, go to Developer Tools > States and select the entity. The attributes are listed below the state value.
Good to know
  • Returns None when the entity or attribute does not exist. Chain with | default(value) for a fallback.
  • Attribute values keep their original type, so numeric attributes like brightness come back as numbers without conversion.
Try it yourself
More examples
Get the brightness of a light
Read how bright a light is currently set.
{{ state_attr("light.living_room", "brightness") }}
Result (integerA whole number without decimal places, like 1, 42, or -5. Used for counts, indices, and whole values.)
178
Get battery level
Check the battery percentage of a device.
{{ state_attr("sensor.phone_battery", "battery_level") }}
85
Use an attribute in a conditionConditions are an optional part of an automation that will prevent an action from firing if they are not met. [Learn more]
Check if the current temperature is below the target temperature.
  state_attr("climate.living_room", "current_temperature")
  < state_attr("climate.living_room", "temperature")
true
Still stuck?
Tip
Related template functions
