Relative time (deprecated): relative_time
The relative_time template function returns a human-readable string describing how long ago a datetimeA value representing a specific moment in time, including the date, time, and time zone. For example, 2026-04-05 14:30:00+00:00. Used for timestamps, scheduling, and time-based calculations. occurred. Give it a datetime in the past, and it returns something like “2 hours” or “3 days”.
This function has been deprecated in favor of time_since, which provides the same functionality with the added ability to control precision. You should use time_since for all new templatesA template is an automation definition that can include variables for the action or data from the trigger values. This allows automations to generate dynamic actions. [Learn more]. relative_time remains available for backward compatibility, but may be removed in a future release.
Usage
{{ relative_time(states.binary_sensor.front_door.last_changed) }}
2 hours
Function signature
relative_time(
    value: datetime,
) -> str
Function parameters
value datetime Required
A datetime object representing a point in the past. The function calculates the time elapsed between this datetime and now.
Migrating to time_since
Replace relative_time with time_since in your templates. The basic usage is identical:
TemplateA template is an automation definition that can include variables for the action or data from the trigger values. This allows automations to generate dynamic actions. [Learn more]: Using time_since instead
{{ time_since(states.binary_sensor.front_door.last_changed) }}
2 hours
The advantage of time_since is the optional precision parameter, which lets you control how many time components to include in the output:
TemplateA template is an automation definition that can include variables for the action or data from the trigger values. This allows automations to generate dynamic actions. [Learn more]: time_since with precision
{{ time_since(states.binary_sensor.front_door.last_changed, 2) }}
2 hours and 30 minutes
Good to know
  • Deprecated. Use time_since for new templates, which supports a precision argument.
  • Only returns the largest time unit. "2 hours" is given, not "2 hours 15 minutes".
Try it yourself
More examples
Show how long ago something happened
Display the elapsed time since a sensor last changed stateThe state holds the information of interest of an entity, for example, if a light is on or off. Each entity has exactly one state and the state only holds one value at a time. However, entities can store attributes related to that state such as brightness, color, or a unit of measurement. [Learn more].
  "Last updated "
  ~ relative_time(states.sensor.temperature.last_changed) ~ " ago"
Last updated 45 minutes ago
Still stuck?
Tip
Related template functions
