Test state attribute: is_state_attr
The is_state_attr template function checks whether a specific attribute of an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] matches a given value. It returns true or false. This is the attribute equivalent of is_state, which checks the main state.
You’ll use this when you need to make decisions based on an entity’s attributes rather than its main state. For example, checking if a light’s color mode is set to color_temp, if a media player’s source is a specific input, or if a deviceA device is a model representing a physical or logical unit that contains entities.‘s battery level is at a certain value. Like is_state, it safely returns false if the entity doesn’t exist.
Usage
{{ is_state_attr("light.desk", "color_mode", "color_temp") }}
true
Function signature
is_state_attr(
entity_id: str,
attribute: str,
value: Any,
) -> bool
Function parameters
To find the exact attribute names and values for an entity, go to Developer Tools > States and select the entity.
Good to know
- Returns
false(not an error) when the entity or attribute does not exist. - The comparison is type-strict.
is_state_attr("light.x", "brightness", "255")isfalsewhen the attribute is the integer255.
Try it yourself
More examples
Check if a media player is playing from a specific source
{{ is_state_attr("media_player.tv", "source", "HDMI 1") }}
true
Use in an automationAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more] conditionConditions are an optional part of an automation that will prevent an action from firing if they are not met. [Learn more]
Only proceed if the climate system is in heating mode.
condition:
- condition: template
value_template: >
{{ is_state_attr("climate.living_room", "hvac_action", "heating") }}
Still stuck?
Related template functions
Get state attribute: state_attr - Returns the value of a specific attribute from an entity’s state.
Test entity state: is_state - Tests if an entity is in a specific state.
Get entity state: states - Returns the state value of an entity, or lets you iterate over all entity states.
Check if entity has a value: has_value - Tests if an entity exists and has a valid state (not unavailable or unknown).
