Require a value is defined: is_defined
The is_defined filter checks that a value is not undefined and forces a template error if it is. If the value is defined, it passes through unchanged. This is a safety mechanism to catch typos and missing variables early rather than having them silently produce empty strings.
By default, Home Assistant is configured to be lenient with undefined variables, meaning a misspelled variable name produces an empty string instead of an error. While this is convenient for smaller templatesA template is an automation definition that can include variables for the action or data from the trigger values. This allows automations to generate dynamic actions. [Learn more], it can make debugging very difficult. If you write {{ sensr.temperature }} instead of {{ sensor.temperature }}, you get a blank value with no indication that anything is wrong. The is_defined filter lets you opt in to strict checking for specific variables, so you get an immediate error that points to the problem.
Usage
{{ my_variable | is_defined }}
the value of my_variable
Function signature
is_defined(
value: Any,
) -> Any
Function parameters
How it works
When you reference a variable that does not exist in a template, it becomes an Undefined object. Normally, this silently renders as an empty string. The is_defined filter detects this and raises an error instead, making the problem visible.
{{ my_var | is_defined }}
This filter is most useful in scriptsScripts are components that allow you to specify a sequence of actions to be executed by Home Assistant when turned on. [Learn more] and automationsAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more] where variables are passed in from outside. It helps you catch cases where a required variable was not provided.
Good to know
- This raises an error on undefined input, which is the opposite of most filters. Use it intentionally to enforce a variable’s presence.
- A value set to
Noneis considered defined and passes through without error.
Try it yourself
More examples
Validate a script variable
Ensure that a required variable was passed into a scriptScripts are components that allow you to specify a sequence of actions to be executed by Home Assistant when turned on. [Learn more] before using it.
action:
- action: notify.mobile
message: >
Reminder: {{ message | is_defined }}
If the message variable was not provided when calling the script, this raises a clear error instead of sending an empty notification.
Guard multiple variables
Apply is_defined to each variable you depend on at the start of a template.
{% set name = target_name | is_defined %}
{% set room = target_room | is_defined %}
{{ name }} is in the {{ room }}
Alice is in the Kitchen
Still stuck?
Related template functions
Check if entity has a value: has_value - Tests if an entity exists and has a valid state (not unavailable or unknown).
Get the type of a value: typeof - Returns the type name of a value as a string.
Test if value is numeric: is_number - Tests whether a value can be converted to a finite number.
