Get floor ID: floor_id
The floor_id template function returns the unique floor ID for a given floor name, areaAn area in Home Assistant is a logical grouping of devices and entities that are meant to match areas (or rooms) in the physical world: your home. For example, the living room area groups devices and entities in your living room. [Learn more] name, deviceA device is a model representing a physical or logical unit that contains entities. ID, or entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] ID. Every floorA floor in Home Assistant is a logical grouping of areas that are meant to match the physical floors in your home. Devices & entities are not assigned to floors but to areas. Floors can be used in automations and scripts as a target for actions. For example, to turn off all the lights on the downstairs floor when you go to bed. [Learn more] in Home Assistant has an internal ID that stays the same even if you rename the floor, and this function lets you look it up.
This is useful when you need the floor ID to pass to other floor functions like floor_areas or floor_entities, or when you want to find out which floor a particular entity, device, or area belongs to. For example, you could use it in an automationAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more] to determine which floor a motion sensorSensors return information about a thing, for instance the level of water in a tank. [Learn more] is on and then act on all devices on that floor.
Usage
{{ floor_id("Ground Floor") }}
ground_floor
Function signature
floor_id(
    lookup_value: str,
) -> str | None
Function parameters
lookup_value string Required
The floor name, area name, entity ID, or device ID to look up. If a floor name is given, the matching floor ID is returned. If an area name, entity ID, or device ID is given, the floor ID of the floor that area, entity, or device belongs to is returned.
Good to know
  • Returns None when the lookup value does not match a floor, or when the area, entity, or device is not assigned to a floor.
  • An entity gets its floor through its area, so an entity with no area returns None.
Try it yourself
More examples
Find the floor of an entity
Look up which floor a specific entity belongs to.
{{ floor_id("sensor.living_room_temperature") }}
ground_floor
Find the floor of an area
Look up which floor a specific area is assigned to by passing its name.
{{ floor_id("Kitchen") }}
ground_floor
Group areas by floor
Combine floor_id with areas to find out which areas belong to each floor.
{% for area_id in areas() %}
  {{ area_name(area_id) }} is on {{ floor_name(floor_id(area_id)) }}
{% endfor %}
Living Room is on Ground Floor
Kitchen is on Ground Floor
Bedroom is on First Floor
Still stuck?
Tip
Related template functions
