Get areas on a floor: floor_areas
The floor_areas template function returns a list of areaAn area in Home Assistant is a logical grouping of devices and entities that are meant to match areas (or rooms) in the physical world: your home. For example, the living room area groups devices and entities in your living room. [Learn more] IDs that belong to a given floorA floor in Home Assistant is a logical grouping of areas that are meant to match the physical floors in your home. Devices & entities are not assigned to floors but to areas. Floors can be used in automations and scripts as a target for actions. For example, to turn off all the lights on the downstairs floor when you go to bed. [Learn more]. You can specify the floor by its name (like “Ground Floor”) or by its internal ID. It gives you all areas that have been assigned to that floor in Home Assistant.
This is useful when you want to work with all areas on a particular floor at once. For example, you could turn off every light on the ground floor at bedtime, check if any room upstairs has an open window, or count how many rooms are on each floor. As you add or remove areas from a floor in Home Assistant, the list automatically updates, so your automationsAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more] and templatesA template is an automation definition that can include variables for the action or data from the trigger values. This allows automations to generate dynamic actions. [Learn more] always stay in sync with your actual setup.
Usage
{{ floor_areas("Ground Floor") }}
"living_room",
"kitchen",
"hallway",
Function signature
floor_areas(
floor_id_or_name: str,
) -> list[str]
Function parameters
The name or ID of the floor. You can find floor IDs in Settings > Areas, labels & zones.
Good to know
- Returns an empty list when the floor does not exist or has no areas assigned.
- Returns area IDs, not human-readable names. Use
area_nameto get the names.
Try it yourself
More examples
Count how many areas are on a floor
Find out how many areas are assigned to a given floor.
{{ floor_areas("Ground Floor") | count }}
3
List the area names on a floor
Loop through all areas on a floor and display their names using area_name.
{% for area_id in floor_areas("Ground Floor") %}
{{ area_name(area_id) }}
{% endfor %}
Living Room
Kitchen
Hallway
Check if any area on a floor has motion
Loop through all areas on a floor and check if any has an active motion sensorSensors return information about a thing, for instance the level of water in a tank. [Learn more]. This uses area_entities to get the entities for each area.
{% for area_id in floor_areas("First Floor") %}
{% if area_entities(area_id)
| select("match", "binary_sensor.")
| select("is_state", "on")
| list
| count > 0 %}
Motion in {{ area_name(area_id) }}!
{% endif %}
{% endfor %}
Still stuck?
Related template functions
Get entities on a floor: floor_entities - Returns a list of entity IDs for all entities on a given floor.
Get floor ID: floor_id - Returns the floor ID for a given floor name, area name, device ID, or entity ID.
Get floor name: floor_name - Returns the friendly name of a floor from its ID, area name, device ID, or entity ID.
Get all floors: floors - Returns a list of all floor IDs in your Home Assistant instance.
Get entities in an area: area_entities - Returns a list of entity IDs associated with a given area.
Get area name: area_name - Returns the friendly name of an area from its ID, entity ID, or device ID.
