Get a device name: device_name
The device_name template function returns the human-readable name of a deviceA device is a model representing a physical or logical unit that contains entities.. You can pass it either a device ID or an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] ID. If a user-set name exists for the device, that name is returned; otherwise, the default device name is used. It returns None if no matching device is found.
This is useful whenever you want to display or include a device’s name in a notificationYou can use notifications to send messages, pictures, and more, to devices. [Learn more], dashboard card, or log message. For example, you could loop through all devices in an areaAn area in Home Assistant is a logical grouping of devices and entities that are meant to match areas (or rooms) in the physical world: your home. For example, the living room area groups devices and entities in your living room. [Learn more] and list their names, or include the device name in an alert so you know exactly which device reported a problem. Since it accepts both device IDs and entity IDs, you can use whichever you happen to have available.
Usage
{{ device_name("a1b2c3d4e5f6a1b2c3d4e5f6") }}
Living Room Thermostat
Function signature
device_name(
device_id_or_entity_id: str,
) -> str | None
Function parameters
Good to know
- Returns
Nonewhen no device matches the lookup value. - Uses the custom name if you set one, otherwise returns the default name the integration provided.
- Renaming a device updates the output immediately, so the result can change over time.
Try it yourself
More examples
Get a device name from an entity ID
Pass an entity ID to find out the name of the device it belongs to.
{{ device_name("sensor.living_room_temperature") }}
Include device name in a notification
Send a notificationYou can use notifications to send messages, pictures, and more, to devices. [Learn more] that includes the name of the device reporting low battery.
action:
- action: notify.mobile
message: >
{{ device_name("binary_sensor.front_door_battery") }}
has a low battery!
List all device names in an area
Combine with area_devices to display the names of all devices in an area.
{% for dev_id in area_devices("Kitchen") %}
{{ device_name(dev_id) }}
{% endfor %}
Still stuck?
Related template functions
Get a device ID: device_id - Returns the device ID for a given entity ID or device name.
Get entities for a device: device_entities - Returns a list of entity IDs associated with a given device.
Get device attribute: device_attr - Returns the value of a specific attribute from a device.
Test device attribute: is_device_attr - Tests if a specific attribute of a device has a given value.
