Get device attribute: device_attr
The device_attr template function returns the value of a specific attribute from a deviceA device is a model representing a physical or logical unit that contains entities. in the device registry. You can pass either a device ID or an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] ID along with the attribute name you want to retrieve. If the device or attribute doesn’t exist, it returns None.
This is useful when you need device-level information that isn’t available through entity states or attributes. For example, you might want to check the manufacturer, model, software version, or serial number of a device. You could use this to track which devices need firmware updates, build a hardware inventory, or include model information in a support request notification. Common attribute names include manufacturer, model, sw_version, hw_version, serial_number, and identifiers.
Usage
{{ device_attr("a1b2c3d4e5f6a1b2c3d4e5f6", "manufacturer") }}
Philips
Function signature
device_attr(
    device_or_entity_id: str,
    attr_name: str,
) -> Any
Function parameters
device_or_entity_id string Required
The device ID or entity ID to look up. When using an entity ID, the function first resolves the device the entity belongs to.
attr_name string Required
The name of the device attribute to retrieve. Common attributes include manufacturer, model, sw_version, hw_version, serial_number, and identifiers.
Tip
To see all available device attributes, go to Developer Tools > States and look at the device registry entries, or use the Devices page in Settings > Devices & services to inspect a specific device.
Good to know
  • Returns None when the device or attribute does not exist, so chain with | default(value) for display fallbacks.
  • This reads from the device registry, not the entity state. Attributes like manufacturer and sw_version live here, not in state_attr.
  • Accepts either a device ID or an entity ID. When given an entity ID, it resolves to the device first.
Try it yourself
More examples
Get the model of a device from an entity ID
You can pass an entity ID directly. The function automatically resolves the device behind the entity.
{{ device_attr("light.living_room", "model") }}
LCA001
Check the firmware version of a device
Read the software version to see if a device is up to date.
{{ device_attr("a1b2c3d4e5f6a1b2c3d4e5f6", "sw_version") }}
1.104.2
Include device info in a notification
Send a notificationYou can use notifications to send messages, pictures, and more, to devices. [Learn more] with the manufacturer and model when a device goes offline.
action:
  - action: notify.mobile
      message: >
        {{ device_name("sensor.garage_door_battery") }} is offline.
        Device:
        {{ device_attr("sensor.garage_door_battery", "manufacturer") }}
        {{ device_attr("sensor.garage_door_battery", "model") }}
Still stuck?
Tip
Related template functions
