Convert to UNIX timestamp: as_timestamp
The as_timestamp template function converts a datetimeA value representing a specific moment in time, including the date, time, and time zone. For example, 2026-04-05 14:30:00+00:00. Used for timestamps, scheduling, and time-based calculations. object or a date/time string into a UNIX timestamp. The result is a floating-point number representing the number of seconds since January 1, 1970 (the UNIX epoch).
UNIX timestamps are useful when you need to perform arithmetic with dates and times, since they are plain numbers that can be added, subtracted, and compared. For example, you can subtract two timestamps to find the number of seconds between two events, or add a number of seconds to find a future time. Many external services and APIs also expect timestamps in this format. You can convert the result back to a readable date using timestamp_custom, timestamp_local, or as_datetime.
Usage
{{ as_timestamp("2024-03-15T14:30:00+01:00") }}
Result (floatA number that can have decimal places, like 21.5 or 3.14. Used for temperatures, percentages, and other measurements that need precision.)
1710510600.0
Function signature
as_timestamp(
    value: datetime | str,
    default: Any = None,
) -> float | Any
Function parameters
value string | datetime Required
The datetime object or date/time string to convert. Strings must be in a recognized date/time format (for example, ISO 8601).
default any (Optional)
Value to return if the conversion fails. If not provided, an error is raised on invalid input.
Converting the current time
You can convert now or utcnow to get the current UNIX timestamp.
{{ as_timestamp(now()) }}
1710510600.0
Using a default value
If the input might be invalid, provide a default to avoid errors.
{{ as_timestamp("not a date", default=0) }}
0
Good to know
  • The result is a UNIX timestamp in seconds (a float), not milliseconds.
  • Without a default, unparseable strings raise an error.
  • Subtracting two timestamps gives a duration in seconds, which can be compared directly with numeric thresholds.
Try it yourself
More examples
Seconds since an entity last changed
Calculate how many seconds have passed since a sensor last changed stateThe state holds the information of interest of an entity, for example, if a light is on or off. Each entity has exactly one state and the state only holds one value at a time. However, entities can store attributes related to that state such as brightness, color, or a unit of measurement. [Learn more].
  (as_timestamp(now())
   - as_timestamp(states.binary_sensor.front_door.last_changed))
  | int
Result (integerA whole number without decimal places, like 1, 42, or -5. Used for counts, indices, and whole values.)
3847
Check if something happened in the last 5 minutes
Determine whether the front door opened in the last 300 seconds.
  < 300
true
Format a timestamp for display
Convert a datetime string to a UNIX timestamp and then format it using timestamp_custom.
  | timestamp_custom("%H:%M")
14:30
Still stuck?
Tip
Related template functions
