Convert to local time zone: as_local
The as_local template function converts a datetimeA value representing a specific moment in time, including the date, time, and time zone. For example, 2026-04-05 14:30:00+00:00. Used for timestamps, scheduling, and time-based calculations. object to your local time zone, as configured in Home Assistant. If you have a datetime in UTC or any other time zone, as_local shifts it to your local time so it displays correctly for you.
Many entitiesAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] in Home Assistant store their timestamps in UTC. When you display these values on a dashboard or use them in a notificationYou can use notifications to send messages, pictures, and more, to devices. [Learn more], you usually want to show the time as it appears on your clock, not in UTC. as_local handles this conversion. For example, if a sensor reports its last update as 13:30 UTC and you live in CET (UTC+1), as_local converts it to 14:30. It also correctly handles daylight saving time changes.
Usage
{{ as_local(utcnow()) }}
Result (datetimeA value representing a specific moment in time, including the date, time, and time zone. For example, 2026-04-05 14:30:00+00:00. Used for timestamps, scheduling, and time-based calculations.)
2024-03-15 14:30:00.123456+01:00
Function signature
as_local(
    value: datetime,
) -> datetime
Function parameters
value datetime Required
The datetime object to convert to the local time zone. Must be a datetime object, not a string. Use as_datetime first if you have a string.
Converting UTC entity timestamps
Entity attributes like last_changed and last_updated are stored in UTC. Convert them to local time for display.
{{ states.binary_sensor.front_door.last_changed | as_local }}
Good to know
  • The input must be a datetime object, not a string. Pipe through as_datetime first if you have a string.
  • Naive datetimes (without time zone info) are treated as UTC before the conversion.
  • Daylight saving transitions are handled automatically based on the Home Assistant configured time zone.
Try it yourself
More examples
Display last changed time in local format
Show when a sensor last changed, formatted in local time.
{{ (states.sensor.temperature.last_changed | as_local).strftime("%H:%M") }}
14:30
Convert a UTC datetime string to local time
First parse the string with as_datetime, then convert to local time.
{{ as_datetime("2024-03-15T13:30:00+00:00") | as_local }}
2024-03-15 14:30:00+01:00
Show the local time of the next scheduled event
Convert a UTC event time from a sensorSensors return information about a thing, for instance the level of water in a tank. [Learn more] to your local time zone for display in a notification.
action:
  - action: notify.mobile
      message: >
        Next appointment at
          (as_datetime(states("sensor.next_appointment")) | as_local)
          .strftime("%H:%M")
Still stuck?
Tip
Related template functions
