Uptime Kuma
The Uptime Kuma integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] connects Home Assistant with your Uptime Kuma monitoring tool.
About Uptime Kuma
Uptime Kuma is an open-source, free, and easy-to-use self-hosted monitoring tool used to track the uptime and performance of websites, applications, and other services.
How you can use this integration
This integration allows you to track the status of your Uptime Kuma monitors directly in Home Assistant. You can use these entities in dashboards, automations, and scripts to react to service outages or monitor uptime trends within your smart home setup.
To set up the Uptime Kuma integration, you need an API key and the URL of your Uptime Kuma instance (for example: https://uptime.example.org).
You can create an API key by logging in to your Uptime Kuma instance, navigating to Settings > API Keys, and selecting Add API Key.
To add the Uptime Kuma service to your Home Assistant instance, use this My button:
If the above My button doesnât work, you can also perform the following steps manually:
From the list, select Uptime Kuma.
Sensors
- Status: The current status of the monitor. Possible states: up, down, pending, or maintenance.
- Response time: Time in milliseconds taken for the last status check.
- Certificate expiry: Number of days remaining before the SSL certificate expires.
- Monitor type: The type of check being performed (e.g., HTTP(s), TCP, ping).
- Monitored hostname: The hostname or IP address being monitored (if applicable).
- Monitored port: The port number used by the monitored service (if applicable).
- Monitored URL: The full URL of the monitored service (if applicable).
- Uptime (1/30/365 days): Uptime ratio in percent, calculated over a sliding window of 1, 30, or 365 days.
- Response time Ă (1/30/365 days): Average response time calculated over a sliding window of 1, 30, or 365 days.
- Tags: Number of tags assigned to the monitor. The full list of tags is available as state attributes.
Update
- Uptime Kuma version: The update entity indicates if Uptime Kuma is up-to-date or if there is a newer Uptime Kuma version available. For more information on how to update your Uptime Kuma instance, please refer to the documentation. If you are using the Uptime Kuma community app for Home Assistant (formerly known as Uptime Kuma add-on), you will receive an update notification in Home Assistant as soon as the Uptime Kuma community app is updated.
Automations
Get started with this automation example to create an Uptime Kuma warning light that changes color based on the monitorâs status.
Example YAML configuration
actions:
- choose:
- conditions:
- condition: state
entity_id: sensor.uptime_kuma_my_service
state: down
sequence:
- action: light.turn_on
color_name: red
entity_id: light.warning_light
- conditions:
- condition: state
state: pending
sequence:
color_name: yellow
- conditions:
- condition: state
state: maintenance
sequence:
color_name: blue
- conditions:
- condition: state
state: up
sequence:
color_name: green
entity_id:
- light.warning_light
triggers:
- trigger: state
entity_id:
- sensor.uptime_kuma_my_service
Examples
Global status binary sensor
If youâd like a single binary sensor that reflects the global status of your Uptime Kuma monitors, you can create a template binary sensor. This sensor will report a problem whenever one or more selected monitors are in a problem state (for example, down, pending, or maintenance).
- Open your Home Assistant Dashboard.
- Go to Settings > Devices & services > Helpers.
- Select Create helper.
- Go to Templates > Binary sensor.
- Fill in the name, for example Uptime Kuma global status.
- Select the device class problem.
- Paste the following state template:
{% set problems = ['down', 'pending', 'maintenance'] %}
{% set has_label = 'my-label' %}
{% set entities = integration_entities('uptime_kuma') | select('match', 'sensor.*_status*') %}
{% set alerts = expand(entities) | selectattr('state', 'in', problems ) | selectattr('entity_id', 'in', label_entities(has_label)) | list %}
{{ alerts | count }}
Replace
my-labelwith your actual label name. -
Adjust
sensor.*_status*if your Home Assistant language or entity naming differs. -
Add the chosen label to all the Uptime Kuma status sensors you want included in this global check.
Data updates
This integration retrieves data from your Uptime Kuma instance every 30 seconds.
Known limitations
- When using Uptime Kuma versions before v2.0.0, Uptime Kumaâs API does not expose unique identifiers for monitors. Because of this, using the same name for multiple monitors will cause only one of them to appear in Home Assistant. Renaming a monitor will result in new entities being created, while the old (stale) entities will remain unless manually removed.
- Paused monitors are not exposed by the API, so Home Assistant cannot distinguish between a deleted monitor and a paused one. As a result, if you delete an Uptime Kuma monitor, the corresponding device entry in Home Assistant must be removed manually.
To remove a monitor from Home Assistant, go to Settings > Devices & services > Uptime Kuma select the three dots
The Uptime Kuma integration relies on an active internet connection to communicate with your Uptime Kuma instance, unless itâs running locally. If you encounter issues, verify that your network connection is stable and your Uptime Kuma instance is accessible.
In any case, when reporting an issue, please enable debug logging, restart the integration, and as soon as the issue reoccurs, stop the debug logging again (download of debug log file will start automatically). Further, if still possible, please also download the diagnostics data. If you have collected the debug log and the diagnostics data, provide them with the issue report.
This integration can be removed by following these steps:
Go to Settings > Devices & services and select the integration card.
Next to the entry you want to remove, select the three dots
- Devices
- Hubs
- Services
- Integration entries
To confirm, select Delete.
If Home Assistant asks you to restart, restart Home Assistant.
If Home Assistant asks whether to also delete the application credentials, select Remove or Keep.
You can now remove the API key used for Home Assistant from Uptime Kuma, unless it is also used by other integrations or applications.
