Theben Conexa Smart Meter Gateway
The Theben Conexa integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] allows you to connect Home Assistant to the Conexa 3.0 device by Theben Smart Energy. A Smart Meter Gateway (SMGW) acts as the secure communication hub for the modern electrical grid. With the Conexa, you get a built-in Home Area Network (HAN) interface. This integration can use that local connection to read your meter data directly, without needing the cloud.
Supported devices
The following device is known to be supported by the integration:
- Conexa 3.0
- To access the HAN interface you need to get the IP address, username, and password from your grid operator.
- Some grid operators need to enable the HAN interface itself as well.
- Optional, but strongly encouraged: Test connectivity and authentication by accessing the web interface of the SMGW (should be
https://IP/). - Make sure that the device running Home Assistant has network connectivity to the SMGW.
To add the Theben Conexa Smart Meter Gateway device to your Home Assistant instance, use this My button:
If the above My button doesnāt work, you can also perform the following steps manually:
From the list, select Theben Conexa Smart Meter Gateway.
The IP address or hostname of your SMGW. For example, 192.168.1.200 or conexa.local. It is defined by your grid operator and canāt be changed by you.
Supported functionality
The Theben Conexa integration provides the following entities.
Sensors
Energy consumed
- Description: The total amount of electrical energy you used from the electricity grid. This should be the same value as your electricity meter shows on its display.
- Remarks: The Conexa SMGW provides a new measurement every 15 minutes.
Energy supplied
- Description: The total amount of electrical energy you supplied to the electricity grid.
- Remarks: The gateway provides this measurement only if your grid operator configures it to do so. For instructions on analyzing raw data from the SMGW over the HAN interface, see the Theben Conexa SMGW wiki. The Conexa SMGW provides a new measurement every 15 minutes.
Data updates
The Theben Conexa integration pollsData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] data from the device every 15 minutes. This is due to a restriction in the current firmware version, which does not allow polling the live meter readings. The SMGW provides a new measurement every 15 minutes based on this scheme: On any given UTC hour hh a new value is provided at hh:00, hh:15, hh:30, and hh:45. This integration therefore polls a few seconds after these times so that you always have access to the latest data in Home Assistant.
Canāt set up the device
Symptom: āThis device canāt be reachedā
When trying to set up the integration, the form shows the message āThis device canāt be reachedā.
Description
Most likely your device running Home Assistant is located in a different IPv4 subnet than your SMGW. Because the SMGW uses a static IP address set by your grid operator, you may need to change your Home Assistant network settings so the devices can reach each other.
Resolution
To resolve this issue, try one of the following options:
- Option 1: Change the DHCP server settings: If your Home Assistant device gets its network settings from a DHCP server (your router), change the DHCP settings so that it assigns IP addresses in the same subnet as your SMGW.
- Option 2: Add another IP address to the Home Assistant device: One network interface can be assigned multiple IP addresses. So for example if your device currently uses
192.168.188.4/24on deviceeth0but the SMGW has the static IP192.168.1.200/24then you can assign for example192.168.1.4/24as another IP foreth0 - Option 3: You have a (semi) professional router: If your router is āsmartā then you can set it up to be connected to both subnets and provide a static route between the two. Hint: Most routers / gateways provided by an ISP are not capable of doing this.
- Devices
- Hubs
- Services
- Integration entries
- To confirm, select Delete.
