Telegram bot
Use Telegram on your mobile or desktop device to send and receive messages or commands to/from your Home Assistant. This integration creates notification actions to send, edit, receive messages or download attachments from a Telegram Bot account.
Introduction - Telegram bot platforms
Platforms are Telegram bot implementations for managing communications with Telegram for sending and receiving messages. When setting up this integration, you should specify the platform which fits your environment and use case.
Broadcast
Telegram implementation to support sending messages only. Your Home Assistant instance does not have to be exposed to the internet and there is no polling to receive messages or commands sent to the bot.
Polling
Telegram chatbot polling implementation. This implementation fetches data from Telegram via long polling with a timeout of 10 seconds. (In long polling, the bot will wait until the timeout expires before fetching the data again if there are no updates from Telegram.)
Your Home Assistant instance does not have to be exposed to the internet.
Webhooks
Telegram chatbot webhooks implementation as described in the Telegram documentation. This implementation allows Telegram to push updates directly to your server and requires your Home Assistant instance to be exposed to the internet.
Create a bot in Telegram
To create your first Telegram bot, follow these steps:
  1. Tell Telegram to create a bot for you:
    • In Telegram, open a chat with @BotFather and enter /newbot.
    • Follow the instructions on screen and give your bot a name.
    • BotFather will give you a link to your new bot and an HTTP API token.
    • Store the API token somewhere safe, it will be used for setting up the integration later.
  2. Get your chat ID:
    • Send any message to @id_bot.
    • Note down the value of the ID field in the bot’s response. You will need to add this ID to the allowlist after setting up the integration to permit your new bot to send/receive messages with this target.
  3. Make the first contact with your new bot (bots are not allowed to initiate contact with users):
    • From the conversation with BotFather, select the link to open a chat.
    • In the chat, enter /start.
Allow Telegram bot to access your Home Assistant files (Optional)
To enable Telegram bot to send local files, you must grant access to it by adding the file’s folder to allowlist_external_dirs.
Example configuration.yaml:
homeassistant:
  allowlist_external_dirs:
    - "/media"
Allow Telegram to connect to your Home Assistant (Webhooks platform only)
Note
This integration currently does not support self-signed certificates for HTTPS. If you are using the Reverse proxy or Direct method, please ensure that your certificates are signed by a public Certificate Authority (CA).
If you plan to use the Webhooks platform, you will need to allow Telegram to connect to your Home Assistant using one of the following methods:
Home Assistant Cloud
If you have a Home Assistant Cloud subscription, you can enable remote access to your Home Assistant.
Reverse proxy
If your Home Assistant is behind a publicly accessible reverse proxy (for example NGINX, Caddy, Traefik) with HTTPS enabled, do the following:
  1. Go to Settings > System > Network and configure Home Assistant URL.
  2. Configure the HTTP integration to allow Home Assistant to accept connections from your reverse proxy:
    • Set use_x_forwarded_for to true.
    • Add the IP address of the reverse proxy to trusted_proxies.
http:
  use_x_forwarded_for: true
  trusted_proxies:
    - 192.168.0.0/16
Direct
If your Home Assistant is publicly accessible, do the following:
  2. Configure the HTTP integration to enable HTTPS on your Home Assistant by configuring the following variables:
    • server_host
    • server_port
    • ssl_certificate
    • ssl_key
To add the Telegram bot service to your Home Assistant instance, use this My button:
  • From the list, select Telegram bot.
Note
When configuring the API endpoint, please note the following protocol requirements:
  • (Default) Official Telegram servers: HTTPS is required.
  • Custom API endpoints: Both HTTP and HTTPS are supported.
Platform
The Telegram bot type, either Broadcast, Polling or Webhooks.
API key
The API token of your bot.
API endpoint
The endpoint of the Telegram bot API server. You should only change this value if you are using a self-hosted or third-party Telegram bot API server. Changing this value will result in a 10-minute lockout on the official Telegram bot API server. Defaults to the official Telegram bot API server at https://api.telegram.org.
Proxy URL
Proxy URL if working behind one, optionally including username and password. (socks5://username:password@proxy_ip:proxy_port).
Webhooks configuration
Note
If you are using Home Assistant Cloud, you must include 127.0.0.1 in the Trusted networks field because the IP address of incoming requests is not forwarded to your Home Assistant.
Note
If you are using a custom API endpoint, you must include the IP address or IP range of the server in CIDR notation, like 192.168.0.0/16, in the Trusted networks field.
If you have selected the Webhooks Telegram bot type, the integration setup will continue with the webhooks configuration step.
URL
Allow to overwrite the external URL from the Home Assistant configuration for different setups (https://<public_url>:<port>).
Trusted networks
Telegram server access ACL as list. Default is 149.154.160.0/20, 91.108.4.0/22.
Options
To define options for Telegram bot, follow these steps:
  1. In Home Assistant, go to Settings > Devices & services.
  2. If multiple instances of Telegram bot are configured, choose the instance you want to configure.
  3. On the card, select the cogwheel .
    • If the card does not have a cogwheel, the integration does not support options for this device.
    Screenshot showing the cogwheel icon on an integration card in the Settings > Devices & services page
  4. Edit the options, then select Submit to save the changes.
Parse mode
Default parser for messages if not explicit in message data, either markdown (legacy), markdownv2, html or plain_text. Refer to Telegram’s formatting options for more information.
Allowlisting chat IDs via Subentries
A Telegram chat ID is a unique numerical identifier for an individual user (positive) or a chat group (negative). You must allowlist the chat ID for the Telegram bot before it can send/receive messages for that chat. To allowlist the chat ID, retrieve the chat ID and create a subentry:
  1. Go to Settings > Devices & services.
  2. Select the Telegram bot integration.
  3. Next to the entry, select the three dots menu. Then, select Add allowed chat ID.
Chat ID
ID representing the user or group chat to which messages can be sent.
Notifiers
This integration will add a notify entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] for each configured chat ID. You can use the notify.send_message action to publish notifications.
Example YAML configuration
action: notify.send_message
  message: "Reminder: Have you considered frogs?"
  entity_id: notify.telegram_bot_chat
Notification actions
Available actions: send_message, send_photo, send_video, send_animation, send_voice, send_sticker, send_document, send_media_group, send_location, send_chat_action, edit_message, edit_message_media, edit_caption, edit_replymarkup, answer_callback_query, delete_message, leave_chat and set_message_reaction.
Chat targets can be specified in any of the following ways:
  • entity_id
  • config_entry_id and chat_id
  • If you only have 1 bot and no chat targets (entity_id or chat_id) were specified, the bot’s first subentry will be used as the default chat.
Actions that send contents (send_*) will return a list of message_id/chat_id for messages delivered (in a property called chats). This will populate Response Data that you can further utilize in your automations to edit/delete the message later based on the message_id. See the example later on this page for usage instructions.
Action telegram_bot.send_message
Send a notification.
Data attribute Optional Description
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for sending the message.
config_entry_id yes The config entry representing the Telegram bot to send the message. Required if you have multiple Telegram bots.
chat_id yes An array of pre-authorized chat_ids or user_ids to send the notification to. Defaults to the first allowed chat_id.
title yes Optional title for your notification. Will be composed as ‘%title\n%message’.
message no Message body of the notification.
parse_mode yes Parser for the message text: markdownv2, html, markdown or plain_text.
disable_notification yes True/false for send the message silently. iOS users and web users will not receive a notification, Android users will receive a notification with no sound. Defaults to False.
disable_web_page_preview yes True/false for disable link previews for links in the message.
resize_keyboard yes True/false for resizing the keyboard vertically for optimal fit. Defaults to False.
one_time_keyboard yes True/false for hiding the keyboard as soon as it’s been used. The keyboard will still be available, but clients will automatically display the usual letter keyboard in the chat - the user can press a special button in the input field to see the custom keyboard again. Defaults to False.
keyboard yes List of rows of commands, comma-separated, to make a custom keyboard. [] to reset to no custom keyboard. Example: ["/command1, /command2", "/command3"]
inline_keyboard yes List of rows of commands, comma-separated, to make a custom inline keyboard with buttons with associated callback data or external URL (https-only). Example: ["/button1, /button2", "/button3"] or [[["Text btn1", "/button1"], ["Text btn2", "/button2"]], [["Google link", "https://google.com"]]]
message_tag yes Tag for sent message. In telegram_sent event data: {{trigger.event.data.message_tag}}
reply_to_message_id yes Mark the message as a reply to a previous message. In telegram_callback handling, for example, you can use {{ trigger.event.data.message.message_id }}
message_thread_id yes Send the message to a specific topic or thread.
This action returns a send message response.
Action telegram_bot.send_photo
Send a photo.
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for sending the photo.
config_entry_id yes The config entry representing the Telegram bot to send the photo. Required if you have multiple Telegram bots.
url no Remote path to an image.
file no Local path to an image.
caption yes The title of the image.
authentication yes Define which authentication method to use. Set to basic for HTTP basic authentication, digest for HTTP digest authentication, or bearer_token for OAuth 2.0 bearer token authentication.
username yes Username for a URL which requires HTTP basic or digest authentication.
password yes Password (or bearer token) for a URL that requires authentication.
verify_ssl yes True/false for checking the SSL certificate of the server for HTTPS URLs. Defaults to True.
one_time_keyboard yes True/false for hiding the keyboard as soon as it’s been used. The keyboard will still be available, but clients will automatically display the usual letter-keyboard in the chat - the user can press a special button in the input field to see the custom keyboard again. Defaults to False.
Action telegram_bot.send_video
Send a video.
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for sending the video.
config_entry_id yes The config entry representing the Telegram bot to send the video. Required if you have multiple Telegram bots.
url no Remote path to a video.
file no Local path to a video.
caption yes The title of the video.
disable_notification yes True/false to send the message silently. iOS users and web users will not receive a notification. Android users will receive a notification with no sound. Defaults to False.
Action telegram_bot.send_animation
Send an animation.
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for sending the animation.
config_entry_id yes The config entry representing the Telegram bot to send the animation. Required if you have multiple Telegram bots.
url no Remote path to a GIF or H.264/MPEG-4 AVC video without sound.
file no Local path to a GIF or H.264/MPEG-4 AVC video without sound.
caption yes The title of the animation.
Action telegram_bot.send_voice
Send a voice message.
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for sending the voice message.
config_entry_id yes The config entry representing the Telegram bot to send the voice message. Required if you have multiple Telegram bots.
url no Remote path to a voice message.
file no Local path to a voice message.
caption yes The title of the voice message.
Action telegram_bot.send_sticker
Send a sticker.
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for sending the sticker.
config_entry_id yes The config entry representing the Telegram bot to send the sticker. Required if you have multiple Telegram bots.
url no Remote path to a static .webp or animated .tgs sticker.
file no Local path to a static .webp or animated .tgs sticker.
sticker_id no ID of a sticker that exists on telegram servers. The ID can be found by sending a sticker to your bot and querying the telegram-api method getUpdates or by using the @idstickerbot
Action telegram_bot.send_document
Send a document.
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for sending the document.
config_entry_id yes The config entry representing the Telegram bot to send the document. Required if you have multiple Telegram bots.
url no Remote path to a document.
file no Local path to a document.
caption yes The title of the document.
Action telegram_bot.send_media_group
Sends a group of photos, videos, documents or audios as an album. Documents and audio files can be only grouped in an album with messages of the same type.
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for sending the media.
config_entry_id yes The config entry representing the Telegram bot to send the media. Required if you have multiple Telegram bots.
media no A list where each item contains the following:
  • media_type: Required. Valid media types: animation, audio, document, photo, or video.
  • url: Remote path to a document.
  • file: Local path to a document.
  • caption: The title of the media.
  • authentication: Define which authentication method to use. Set to basic for HTTP basic authentication, digest for HTTP digest authentication, or bearer_token for OAuth 2.0 bearer token authentication.
  • username: Username for a URL which requires HTTP basic or digest authentication.
  • password: Password (or bearer token) for a URL that requires authentication.
  • verify_ssl: True/false for checking the SSL certificate of the server for HTTPS URLs. Defaults to True.
protect_content yes Protects the contents of the sent message from forwarding and saving.
Action telegram_bot.send_location
Send a location.
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for sending the location.
config_entry_id yes The config entry representing the Telegram bot to send the location. Required if you have multiple Telegram bots.
latitude no The latitude to send.
longitude no The longitude to send.
Action telegram_bot.send_poll
Send a poll.
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for sending the poll.
config_entry_id yes The config entry representing the Telegram bot to send the poll. Required if you have multiple Telegram bots.
question no Poll question, 1-300 characters.
options no List of answer options, 2-10 strings 1-100 characters each.
is_anonymous yes True/false for if the poll needs to be anonymous, defaults to True.
allows_multiple_answers yes True/false for if the poll allows multiple answers, defaults to False.
open_period yes Amount of time in seconds the poll will be active after creation, 5-600.
Action telegram_bot.send_chat_action
Send a chat action. Use it to notify the user with the relevant “typing” action when a bot response may be delayed, so they know a message is coming soon. Telegram clears this status after 5 seconds or when the reply arrives.
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for sending the chat action.
config_entry_id yes The configuration entry representing the Telegram bot to send the message. Required if you have multiple Telegram bots.
chat_action no Chat action to be sent: typing, upload_photo, record_video, upload_video, record_voice, upload_voice, upload_document, choose_sticker, find_location, record_video_note, upload_video_note.
Action telegram_bot.edit_message
Edit a previously sent message in a conversation.
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for editing the message.
config_entry_id yes The config entry representing the Telegram bot to edit the message. Required if you have multiple Telegram bots.
chat_id yes The chat_id where to edit the message.
message_id no Id of the message to edit. When answering a callback from a pressed button, the id of the origin message is in: {{ trigger.event.data.message.message_id }}. You can use "last" to refer to the last message sent to chat_id.
Action telegram_bot.edit_message_media
Edit a previously sent message media in a conversation.
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for editing the message media.
config_entry_id yes The config entry representing the Telegram bot to edit the message media. Required if you have multiple Telegram bots.
chat_id yes The ID of the chat in which you want to edit the message media.
message_id no ID of the message to edit. When reacting to a pressed button, the ID of the origin message is in: {{ trigger.event.data.message.message_id }}. You can use "last" to refer to the last message sent to chat_id.
media_type no The media type: animation, audio, document, photo, or video.
url no Remote path to the media.
file no Local path to the media.
caption yes The title of the media.
Action telegram_bot.edit_caption
Edit the caption of a previously sent message.
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for editing the caption.
config_entry_id yes The config entry representing the Telegram bot to edit the caption. Required if you have multiple Telegram bots.
chat_id yes The chat_id where to edit the caption.
caption no Message body of the notification.
Action telegram_bot.edit_replymarkup
Edit the inline keyboard of a previously sent message.
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for editing the inline keyboard.
config_entry_id yes The config entry representing the Telegram bot to edit the inline keyboard. Required if you have multiple Telegram bots.
chat_id yes The chat_id where to edit the reply_markup.
Action telegram_bot.answer_callback_query
Respond to a callback query originated by clicking on an online keyboard button. The answer will be displayed to the user as a notification at the top of the chat screen or as an alert.
config_entry_id yes The config entry representing the Telegram bot to answer the callback query. Required if you have multiple Telegram bots.
message no Unformatted text message body of the notification.
callback_query_id no Unique id of the callback response. In the telegram_callback event data: {{ trigger.event.data.id }}
show_alert yes True/false for show a permanent notification. Defaults to False.
Action telegram_bot.delete_message
Delete a previously sent message in a conversation.
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for deleting the message.
config_entry_id yes The config entry representing the Telegram bot to delete the message. Required if you have multiple Telegram bots.
chat_id yes The chat_id where to delete the message.
message_id no Id of the message to delete. When answering a callback from a pressed button, the id of the origin message is in: {{ trigger.event.data.message.message_id }}. You can use "last" to refer to the last message sent to chat_id.
Action telegram_bot.leave_chat
Remove the bot from the chat group where it was added.
entity_id yes Notify entities where each entity has its corresponding Telegram bot and chat for leaving the chat.
config_entry_id yes The config entry representing the Telegram bot to leave the chat. Required if you have multiple Telegram bots.
chat_id yes The chat_id from where to remove the bot.
Action telegram_bot.set_message_reaction
Sets the bot’s reaction for a given message.
Data data attribute Optional Description
config_entry_id yes The config entry representing the Telegram bot to set the message reaction. Required if you have multiple Telegram bots.
chat_id yes Id of the chat containing the message.
message_id no Id of the message to react to.
reaction no Emoji to react to the message with.
is_big yes Whether to use a large variant of the reaction animation.
Action telegram_bot.download_file
Download a file previously sent to the bot and save it to a local path on the Home Assistant host.
config_entry_id yes The config entry representing the Telegram bot to get the file. Required if you have multiple Telegram bots.
file_id no ID of the file to get. This is provided in telegram_attachment event data as file_id.
directory_path yes Local directory path to save the file to. Defaults to /config/telegram_bot/.
file_name yes Name to save the file as. If not provided, the original file name will be used.
Example YAML usage:
action: telegram_bot.download_file
  config_entry_id: "<your_config_entry_id>"
  file_id: "ABCD1234Efgh5678Ijkl90mnopQRStuvwx"
  directory_path: "/config/telegram_bot/"
  file_name: "my_downloaded_file"
Note
  • For file size limits and download behavior, refer to the python-telegram-bot documentation: python-telegram-bot - get_file
  • For the moment, bots can download files of up to 20 MB in size.
  • Ensure the target directory_path is included in allowlist_external_dirs if you need to serve or access the file from the frontend.
Response schemas for actions
Tip
Responses can be accessed using the response_variable of actions. You can refer to the send a message then edit it after a delay automation for an example of usage of the response.
Send message response
Response schema:
Data attribute Optional Type Description
chats no list A list of chat objects. Each object represents a successful message sent.
Chat object schema:
chat_id no integer The target chat_id of the sent message.
message_id no integer The id of the message.
entity_id no string The entity id of the notify entity.
Example response:
chats:
  - chat_id: 1234567890
    message_id: 100
  - chat_id: -1234567890
    message_id: 200
Telegram notification platform
Warning
The notification platform has been marked as legacy and might be deprecated in the future. Please use notifiers instead.
The telegram notification platform requires the telegram_bot integration to work with, and it’s designed to generate a customized shortcut (notify.USERNAME) to send notifications (messages, photos, documents, and locations) to a particular chat_id with the old syntax, allowing backward compatibility. The data attributes parse_mode, disable_notification, message_tag, disable_web_page_preview, and message_thread_id are also supported.
The required YAML configuration now reduces to:
notify:
  - platform: telegram
    chat_id: USER_CHAT_ID
Event entity
The Telegram bot integration provides an eventEvery time something happens in Home Assistant, an event is fired. There are different types of events, such as state change events, when an action was triggered, or the time changed. All entities produce state change events. Every time a state changes, a state change event is produced. Events can be used to trigger automations or scripts. For example, you can trigger an automation when a light is turned on, then a speaker turns on in that room. Events can also be used to trigger actions in the frontend. For example, you can trigger an action when a button is pressed. [Learn more] entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] which represents the state of the last message sent or received. It also provides several event attributes that can be used in automations.
Event: Attachment received
The telegram_attachment event is triggered when the bot receives a file.
Example event attributes:
bot:
  config_entry_id: "<config entry id of the bot>"
  first_name: "<first name of the bot>"
  id: "<id of the bot>"
  last_name: "<last name of the bot>"
  username: "<username of the bot>"
chat_id: "<origin chat id>"
date: "<message timestamp>"
event_type: "telegram_attachment"
file_id: "<unique identifier for the file>"
file_mime_type: "<MIME type of the file, if available>"
file_name: "<name of the file, if available>"
file_size: "<file size in bytes, if available>"
friendly_name: "<name of the event entity>"
from_first: "<first name of the sender>"
from_last: "<last name of the sender>"
message_thread_id: "<message thread id>"
text: "<caption of the file, if available>"
user_id: "<id of the sender>"
Example automation:
triggers:
  - trigger: state
    entity_id:
      - event.bot_update_event # Replace with your telegram bot event entity
conditions:
  - condition: state
    entity_id: event.bot_update_event # Replace with your telegram bot event entity
    attribute: event_type
    state: telegram_attachment
actions:
  - action: notify.persistent_notification
      message: >-
        Received a file.
        MIME type   : {{ trigger.to_state.attributes.file_mime_type }}
        Size (bytes): {{ trigger.to_state.attributes.file_size }}
        File ID     : {{ trigger.to_state.attributes.file_id }}
        File name   : {{ trigger.to_state.attributes.file_name }}
Event: Callback query received
The telegram_callback event is triggered when the bot receives a callback query from an inline keyboard button.
Tip
The id attribute is used as the callback_query_id parameter for the answer_callback_query action.
# Callback query always have no args
args: []
bot:
chat_instance: "<chat instance id>"
command: "<callback query>"
data: "<data associated to action callback>"
event_type: "telegram_callback"
message: "<message origin of the action callback>"
Example automation:
triggers:
  - trigger: state
    entity_id:
conditions:
  - condition: state
    state: telegram_callback
actions:
      message: >-
        Received callback query.
        Callback ID   : {{ trigger.to_state.attributes.id }}
        Callback query: {{ trigger.to_state.attributes.data }}
Event: Command received
The telegram_command event is triggered when the bot receives a command. A command looks like /thecommand or /othercommand with some args.
args: "<any other text following the command>"
bot:
command: "/thecommand"
event_type: "telegram_command"
Example automation:
triggers:
  - trigger: state
    entity_id:
conditions:
  - condition: state
    state: telegram_command
actions:
      message: >-
        Received command.
        Command: {{ trigger.to_state.attributes.command }}
        Args   : {{ trigger.to_state.attributes.args }}
Event: Text received
The telegram_text event is triggered when the bot receives a text message (any message that does not begin with /).
bot:
event_type: "telegram_text"
text: "<the text received>"
Example automation:
triggers:
  - trigger: state
    entity_id:
conditions:
  - condition: state
    state: telegram_text
actions:
      message: >-
      Message received.
      Chat ID   : {{ trigger.to_state.attributes.chat_id }}
      First name: {{ trigger.to_state.attributes.from_first }}
      Last name : {{ trigger.to_state.attributes.from_last }}
      Message   : {{ trigger.to_state.attributes.text }}
Event: Message sent
The telegram_sent event is triggered when the bot sends a message of any type.
Tip
The message_id attribute can be used with the edit, delete and set_message_reaction actions to interact with a previously sent message.
bot:
Example automation:
triggers:
  - trigger: state
    entity_id:
conditions:
  - condition: state
    state: telegram_sent
actions:
      message: >-
      Bot sent a message.
      Message ID: {{ trigger.to_state.attributes.message_id }}
Sample automations with inline keyboards and callback queries
A quick example to show some of the callback capabilities of inline keyboards with a dumb automation consisting in a simple repeater of normal text that presents an inline keyboard with 3 buttons: ‘EDIT’, ‘NO’ and ‘REMOVE BUTTON’:
  • Pressing ‘EDIT’ changes the sent message.
  • Pressing ‘NO’ only shows a brief notification (answering the callback query).
  • Pressing ‘REMOVE BUTTON’ changes the inline keyboard removing that button.
Text repeater:
alias: Telegram bot that repeats text
triggers:
  - trigger: state
    entity_id:
conditions:
  - condition: state
actions:
  - action: telegram_bot.send_message
      message: "You said: {{ trigger.to_state.attributes.text }}"
      title: "*Dumb automation*"
      disable_notification: true
      inline_keyboard:
        - Edit message:/edit_msg, Don't:/do_nothing
        - Remove this button:/remove_button
Message editor:
alias: Telegram bot that edits the last sent message
description: ""
triggers:
  - trigger: state
    entity_id:
conditions:
  - condition: state
  - condition: state
    attribute: command
    state: /edit_msg
actions:
  - action: telegram_bot.answer_callback_query
      show_alert: true
      message: Editing the message!
      callback_query_id: "{{ trigger.to_state.attributes.id }}"
  - action: telegram_bot.edit_message
      inline_keyboard:
      message_id: "{{ trigger.to_state.attributes.message.message_id }}"
      chat_id: "{{ trigger.to_state.attributes.chat_id }}"
      title: "*Message edit*"
      message: >-
        Callback received from {{ trigger.to_state.attributes.from_first }}.
        Message id: {{ trigger.to_state.attributes.message.message_id }}.
        Data: {{ trigger.to_state.attributes.data|replace("_", "\_") }}
Keyboard editor:
alias: Telegram bot that edits the keyboard
triggers:
  - trigger: state
    entity_id:
conditions:
  - condition: state
  - condition: state
    attribute: command
    state: /remove_button
actions:
      message: Callback received for editing the inline keyboard!
      show_alert: false
  - action: telegram_bot.edit_replymarkup
      inline_keyboard:
      message_id: last
Only acknowledges the ‘NO’ answer:
alias: Telegram bot that simply acknowledges
triggers:
  - trigger: state
    entity_id:
conditions:
  - condition: state
  - condition: state
    attribute: command
    state: /do_nothing
actions:
      message: OK, you said no!
Sample automation to receive chat_id and message_id identifiers of sent messages
The following sample automation stores the chat_id and message_id of the last sent message using input entities. These attributes can then be used in other Telegram bot actions.
alias: Notifications about messages sent by Telegram bot
triggers:
  - trigger: state
    entity_id:
conditions:
  - condition: state
actions:
  - action: input_number.set_value
    data_template:
      value: "{{ trigger.to_state.attributes.chat_id }}"
      entity_id: input_number.chat_id # Replace with your input entity
    data_template:
      value: "{{ trigger.to_state.attributes.message_id }}"
      entity_id: input_number.message_id # Replace with your input entity
Example: send_message with formatted Text
actions:
      title: Example Message
      message: 'Message with *BOLD*, _ITALIC_ and `MONOSPACE` Text'
Example: send_message with message tag
actions:
      message: "Message with tag"
      message_tag: "example_tag"
Example: send_message with disabled webpage preview
actions:
      message: >-
        <a href="https://www.home-assistant.io/">HA site</a>
      parse_mode: html
      disable_web_page_preview: true
Example: send_message then edit it after a delay
actions:
      message: testing
    response_variable: response
  - delay:
      seconds: 5
      message: done testing
      chat_id: "{{ response.chats[0].chat_id }}"
      message_id: "{{ response.chats[0].message_id }}"
Example: send_message to a topic within a group
actions:
      message: "Message to a topic"
      message_thread_id: 123
Example: send_media_group
actions:
  - action: telegram_bot.send_media_group
      media:
        - url: https://example/image.jpg
          caption: My album
          media_type: photo
        - url: https://example/video.mp4
          media_type: video
Example: automation to send a message and delete after a delay
alias: telegram send message and delete
actions:
      message: testing
  - delay:
      seconds: 5
  - repeat:
      sequence:
        - action: telegram_bot.delete_message
            message_id: "{{ repeat.item.message_id }}"
            chat_id: "{{ repeat.item.chat_id }}"
      for_each: "{{ response.chats }}"
Known limitations
The following features are not available in this integration:
  • Editing the bot (You can edit the bot using @BotFather on the Telegram app instead)
  • All payment related features such as Telegram Premium, Telegram Star and Telegram Gifts
  • Telegram Business
  • Telegram ADS
  • Mini Bot Apps and Mini Bot Store
  • Calls and live streaming
  • Wallpapers and Themes
Error sending message: Can’t parse entities
When using send actions such as telegram_bot.send_message with the markdownv2 parse mode, the action will fail with the “Can’t parse entities” error if the user input in the message field contains malformed Markdown syntax.
You can perform any of the following steps to resolve this issue:
  • Use the plain_text parse mode either by configuring the Telegram bot options or by specifying it via the action’s parse_mode data attribute.
  • Escape special characters in the message field with a preceding ‘\’ character.
  • Format your message according to the formatting options.
Telegram Webhook bot is unable to receive updates
If your Telegram bot is unable to receive updates (for example, all events other than telegram_sent are not triggered), please follow the troubleshooting steps below:
  1. Reconfigure your Telegram bot to use the Polling platform and test again to verify that the issue is not related to network connectivity between Telegram and your Home Assistant.
  2. Check your firewall rules to verify that incoming connections are not blocked.
  3. Verify that your webhook URL is public and accessible.
If the issue persists, please refer to the Webhooks Guide for more detailed troubleshooting.
