SilverCrest Infrared
The SilverCrest Infrared integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you control SilverCrest infrared devices with any infrared emitter that has been previously configured in Home Assistant.
Because the integration communicates over infrared, it operates in a one-way, fire-and-forget fashion: commands are sent to the device, but there is no feedback channel to confirm its current state. The integration therefore uses assumed states.
How you can use the integration
After setup, you can control your SilverCrest devices from Home Assistant with the created entities. Use it to turn the device on or off or control other features.
Supported devices
The following SilverCrest infrared devices are supported:
  • Portable air cooler SML 330 A1
  • Pedestal fan SSVF 45 A1
  • Pedestal fan SSVF 45 B1
  • Pedestal fan SSVF 45 C1
  • Misting pedestal fan SSVS 85 A1
  • Misting pedestal fan SSVS 85 B2
  • Tower fan STVD 45 A1
  • Tower fan STVL 50 B1
  • Tower fan STVL 50 C1
  • Pedestal fan SV 60 A1
  • Pedestal fan SV 60 A2
Unsupported devices
This integration supports only devices controlled via infrared (IR). Bluetooth- and Wi-Fi-controlled devices are not supported.
Other IR-controlled devices may also work if they use compatible infrared commands. However, these devices have not been tested, and some functions or buttons may not be supported.
Contributing support for additional devices
If you own an unsupported IR-controlled device, you can help extend the integration by capturing its infrared codes and opening a feature request.
When submitting a request, include the device model and the captured infrared codes, along with any relevant details about its available functions.
This integration requires an infrared remote adapter (proxy) that is already set up in Home Assistant and provides an infrared entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more]. To find integrations that provide infrared entities, browse the Infrared category.
For example, you can use an ESPHome device with an IR LED pointed at your SilverCrest device.
To add the SilverCrest Infrared device to your Home Assistant instance, use this My button:
  • From the list, select SilverCrest Infrared.
Select the device type that matches your remote control, then select an infrared emitter.
Device type
The type of SilverCrest device to control.
Infrared emitter
The infrared emitter entity to use for sending commands to your device. This must be an entity provided by a hardware integration (such as ESPHome) that has already been set up with an IR emitter.
Supported functionality
The SilverCrest integration provides the following entities.
Buttons
  • Power
    • Description: Turns the fan on or off.
    • Available for: All supported fans.
  • Speed
    • Description: Cycles through the available speed settings.
  • Timer
    • Description: Cycles through the available timer settings and the off option.
  • Oscillation
    • Description: Toggles the fan’s oscillation function.
  • Mode
    • Description: Cycles through the available fan modes, such as Sleep and Nature, and the off option, where supported.
    • Available for: Pedestal fans, tower fans, and air coolers.
  • Mist
    • Description: Toggles the misting function.
    • Available for: Misting pedestal fans.
SilverCrest Infrared automation examples
Use the fan’s button entities in automations to send commands when something happens in your home.
Tip
Automation: Toggle the fan when a room is occupied and too warm
The following example presses the fan’s Power button when a room becomes occupied and the temperature is above 25 °C. Because this button toggles the fan, this example assumes the fan is off when the room becomes occupied. Replace the example entity IDs and temperature threshold with values for your Home Assistant instance.
  • Trigger: Room occupancy detected
  • Condition: Room temperature is above 25 °C
  • Action: Press the fan’s Power button
alias: "Toggle the fan when the room is occupied and too warm"
triggers:
  - trigger: state
    entity_id: binary_sensor.room_occupancy
    to: "on"
conditions:
  - condition: numeric_state
    entity_id: sensor.room_temperature
    above: 25
actions:
  - action: button.press
      entity_id: button.silvercrest_tower_fan_power
Known limitations
Device state
The integration uses assumed state, meaning Home Assistant cannot read the actual state of the device (for example, whether it is on or off, or what the current fan speed is).
Multiple fans
You can use only one SilverCrest fan with each infrared emitter. Different SilverCrest fan models use the same infrared codes, so one emitter cannot control multiple fans independently.
The device does not respond to commands
Symptom
You press a button in Home Assistant, but the device does not respond.
Resolution
  1. Make sure the infrared emitter selected for the integration is available in Home Assistant.
  2. Make sure the emitter is pointed at the device’s infrared receiver and has a clear line of sight. For more details, see About device placement and coverage.
More than one fan responds to commands
Symptom
A command sent to one SilverCrest fan also affects another fan.
Resolution
SilverCrest fan models use the same infrared codes. To control multiple fans, use a separate emitter for each fan and place the fans and emitters so each emitter has a clear line of sight to its fan, but not to the other fans. For example, place them in different rooms or out of sight of one another. For more information, see Multiple fans.
For additional troubleshooting steps and guidance, see the infrared troubleshooting section.
If you need to report an issue, enable debug logging, then reload the integration. Reproduce the issue, disable debug logging, and attach the automatically downloaded debug log to your report.
      • Devices
      • Hubs
      • Services
      • Integration entries
  3. To confirm, select Delete.
