Command line
The Command line integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] offers functionality that issues specific commands to get data or to control a device.
It’s highly recommended to enclose the command in single quotes ' as it ensures all characters can be used in the command and reduces the risk of unintentional escaping. To include a single quote in a command enclosed in single quotes, double it: ''.
The platforms to use for you command_line integration.
Binary sensor platform.
The action to take to get the value.
Defines a template for the icon of the entity.
An ID that uniquely identifies this binary sensor. Set this to a unique value to allow customization through the UI.
Defines a template to extract a value from the payload.
Defines a template to get the available state of the entity. If the template either fails to render or returns True, "1", "true", "yes", "on", "enable", or a non-zero number, the entity will be available. If the template returns any other value, the entity will be unavailable. If not configured, the entity will always be available. Note that string comparisons are not case sensitive; "TrUe" and "yEs" are allowed.
Cover platform.
If given, this will act as a sensor that runs in the background and updates the state of the cover. If the command returns a 0 the indicates the cover is fully closed, whereas a 100 indicates the cover is fully open.
An ID that uniquely identifies this cover. Set this to a unique value to allow customization through the UI.
if specified, command_state will ignore the result code of the command but the template evaluating will indicate the position of the cover. For example, if your command_state returns a string “open”, using value_template as in the example configuration above will allow you to translate that into the valid state 100.
Notify platform.
Setting the optional parameter name allows multiple notifiers to be created. The notifier will bind to the notify.NOTIFIER_NAME action.
The action to take.
Sensor platform.
Defines a list of keys to extract values from a JSON dictionary result and then set as sensor attributes.
A JSONPathjson_attributes in the JSON content.
An ID that uniquely identifies this sensor. Set this to a unique value to allow customization through the UI.
Sets the class of the device, changing the device state and icon that is displayed on the UI (see below). It does not set the unit_of_measurement.
The state_class of the sensor. This will display the value based on the Number Format defined in the user profile.
Switch platform.
If given, this command will be run. Returning a result code 0 will indicate that the switch is on.
An ID that uniquely identifies this switch. Set this to a unique value to allow customization through the UI.
If specified, command_state will ignore the result code of the command but the template evaluating to true will indicate the switch is on.
For sensors, while value_template is optional, if you set json_attributes because the output is a JSON, it is suggested to provide a template in the value_template field to provide a state to the sensor or the state will always be unknown. See example below.
As Command line integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] is a yaml only integration, turning on extended logging needs to be done by setting the logging information in your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file.
Entering this example in your configuration sets the default logging to info, and for command_line to debug. Once done, restart Home Assistant to enable.
# Set logging
logger:
default: info
logs:
homeassistant.components.command_line: debug
While command is accepting a template for sensor and binary_sensor, it’s only the arguments that can be a template. This means the command name itself cannot be generated by a template, but it must be literally provided.
Using templates
For incoming data, a value template translates incoming JSON or raw data to a valid payload.
Incoming payloads are rendered with possible JSON values, so when rendering, the value_json can be used to access the attributes in a JSON based payload, otherwise the value variable can be used for non-json based data.
Additional, the this can be used as variables in the template. The this attribute refers to the current entity state of the entity.
Further information about this variable can be found in the template documentation
Example value template with json:
With given payload:
{ "state": "ON", "temperature": 21.902 }
Template {{ value_json.temperature | round(1) }} renders to 21.9.
Binary sensor
To use your Command binary sensor in your installation, add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file:
command_line:
- binary_sensor:
command: "cat /proc/sys/net/ipv4/ip_forward"
payload_on: "1"
payload_off: "0"
- binary_sensor:
command: "echo 1"
payload_on: "1"
payload_off: "0"
Cover
A command_linecover platform that issues specific commands when it is moved up, down and stopped. It allows anyone to integrate any type of cover into Home Assistant that can be controlled from the command line.
To enable a command line cover in your installation, add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file:
command_line:
- cover:
command_open: move_command up garage
command_close: move_command down garage
command_stop: move_command stop garage
Notify
The command_line platform allows you to use external tools for notifications from Home Assistant. The message will be passed in as STDIN.
To enable those notifications in your installation, add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file:
command_line:
- notify:
command: "espeak -vmb/mb-us1"
To use notifications, please see the getting started with automation page.
Sensor
To enable it, add the following lines to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more]:
command_line:
- sensor:
command: SENSOR_COMMAND
- sensor:
command: SENSOR_COMMAND_2
Switch
The command_line switch platform issues specific commands when it is turned on
and off. This might very well become our most powerful platform as it allows
anyone to integrate any type of switch into Home Assistant that can be
controlled from the command line, including calling other scripts!
command_line:
- switch:
command_on: switch_command on kitchen
command_off: switch_command off kitchen
A note on name for cover and switch:
The use of friendly_name and object_id has been deprecated and the slugified name will also be used as identifier.
Use unique_id to enable changing the name from the UI and if required, use the slugified name as identifier.
Execution
The command is executed within the configuration directory.
If you are using Home Assistant Operating Systemhomeassistant container context. So if you test or debug your script, it might make sense to do this in the context of this container to get the same runtime environment.
With a 0 exit code, the output (stdout) of the command is used as value. In case a command results in a non 0 exit code or is terminated by the command_timeout, the result is only logged to Home Assistant log and the sensors value is not updated.
Examples binary sensor platform
In this section you find some real-life examples of how to use the command_line sensor.
SickRage
Check the state of an SickRage
command_line:
- binary_sensor:
command: 'netstat -na | grep "33322" | grep -q "LISTENING" > nul && (echo "Running") || (echo "Not running")'
device_class: moving
payload_on: "Running"
payload_off: "Not running"
Check RasPlex
Check if RasPlexonline.
command_line:
- binary_sensor:
command: 'ping -c 1 rasplex.local | grep "1 received" | wc -l'
device_class: connectivity
payload_on: 1
payload_off: 0
An alternative solution could look like this:
command_line:
- binary_sensor:
command: 'ping -W 1 -c 1 192.168.1.10 > /dev/null 2>&1 && echo success || echo fail'
payload_on: "success"
payload_off: "fail"
Consider to use the ping sensor as an alternative to the samples above.
Check if a system service is running
The services running is listed in /etc/systemd/system and can be checked with the systemctl command:
$ systemctl is-active [email protected]
active
$ sudo service [email protected] stop
inactive
A binary command line sensor can check this:
command_line:
- binary_sensor:
command: '/bin/systemctl is-active [email protected]'
payload_on: "active"
payload_off: "inactive"
Example cover platform
command_line:
- cover:
command_state: state_command garage
value_template: >
{% if value == 'open' %}
100
{% elif value == 'closed' %}
0
{% endif %}
Examples sensor platform
CPU temperature
Thanks to the procconfiguration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file:
command_line:
- sensor:
name: CPU Temperature
command: "cat /sys/class/thermal/thermal_zone0/temp"
# If errors occur, make sure configuration file is encoded as UTF-8
unit_of_measurement: "°C"
value_template: "{{ value | multiply(0.001) | round(1) }}"
Details about the upstream Home Assistant release
You can see directly in the frontend (Developer tools -> About) what release of Home Assistant you are running. The Home Assistant releases are available on the Python Package Index
command_line:
- sensor:
command: python3 -c "import requests; print(requests.get('https://pypi.python.org/pypi/homeassistant/json').json()['info']['version'])"
Read value out of a remote text file
If you own devices which are storing values in text files which are accessible over HTTP then you can use the same approach as shown in the previous section. Instead of looking at the JSON response we directly grab the sensor’s value.
command_line:
- sensor:
command: python3 -c "import requests; print(requests.get('http://remote-host/sensor_data.txt').text)"
Use an external script
The example is doing the same as the aREST sensor but with an external Python script. It should give you an idea about interfacing with devices which are exposing a RESTful API.
The one-line script to retrieve a value is shown below. Of course it would be possible to use this directly in the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file but need extra care about the quotation marks.
python3 -c "import requests; print(requests.get('http://10.0.0.48/analog/2').json()['return_value'])"
The script (saved as arest-value.py) that is used looks like the example below.
#!/usr/bin/python3
from requests import get
response = get("http://10.0.0.48/analog/2")
print(response.json()["return_value"])
To use the script you need to add something like the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file.
command_line:
- sensor:
command: "python3 /path/to/script/arest-value.py"
Usage of templating in command:
Templates are supported in the command configuration variable. This could be used if you want to include the state of a specific sensor as an argument to your external script.
command_line:
- sensor:
name: Wind direction
command: "sh /home/pi/.homeassistant/scripts/wind_direction.sh {{ states('sensor.wind_direction') }}"
unit_of_measurement: "Direction"
Usage of JSON attributes in command output
The example shows how you can retrieve multiple values with one sensor (where the additional values are attributes) by using value_json and json_attributes.
command_line:
- sensor:
json_attributes:
- date
- milliseconds_since_epoch
command: "python3 /home/pi/.homeassistant/scripts/datetime.py"
value_template: "{{ value_json.time }}"
JSONPlaceholder
command_line:
- sensor:
command: python3 -c "import requests; print(requests.get('https://jsonplaceholder.typicode.com/users').text)"
json_attributes_path: "$.[0].address"
json_attributes:
- street
- suite
- city
- zipcode
value_template: "{{ value_json[0].name }}"
Example switch platform
Change the icon when a state changes
This example demonstrates how to use template to change the icon as its state changes. This icon is referencing its own state.
command_line:
- switch:
name: Driveway outside sensor
command_on: >
curl -X PUT -d '{"on":true}' "http://ip_address/api/sensors/27/config/"
command_off: >
curl -X PUT -d '{"on":false}' "http://ip_address/api/sensors/27/config/"
command_state: curl http://ip_address/api/sensors/27/
value_template: >
{{value_json.config.on}}
icon: >
{% if value_json.config.on == true %} mdi:toggle-switch
{% else %} mdi:toggle-switch-off
{% endif %}
aREST device
The example below is doing the same as the
aREST switch.
The command line tool curl
command_line:
- switch:
command_on: "/usr/bin/curl -X GET http://192.168.1.10/digital/4/1"
command_off: "/usr/bin/curl -X GET http://192.168.1.10/digital/4/0"
command_state: "/usr/bin/curl -X GET http://192.168.1.10/digital/4"
value_template: '{{ value == "1" }}'
name: Kitchen Lightswitch
Given this example, in the UI one would see the friendly_name of
“Kitchen Light”. However, the identifier is arest_pin_four, making the
entity_id switch.arest_pin_four, which is what one would use in
automation or in API calls.
Shutdown your local host
This switch will shutdown your system that is hosting Home Assistant.
This switch will shutdown your host immediately, there will be no confirmation.
command_line:
- switch:
name: Home Assistant System Shutdown
command_off: "/usr/sbin/poweroff"
Control your VLC player
This switch will control a local VLC media player (Source).
command_line:
- switch:
command_on: "cvlc 1.mp3 vlc://quit &"
command_off: "pkill vlc"
Control Foscam motion sensor
This switch will control the motion sensor of Foscam Webcams which Support CGI
Commands (Source
command_line:
- switch:
command_on: 'curl -k "https://ipaddress:443/cgi-bin/CGIProxy.fcgi?cmd=setMotionDetectConfig&isEnable=1&usr=admin&pwd=password"'
command_off: 'curl -k "https://ipaddress:443/cgi-bin/CGIProxy.fcgi?cmd=setMotionDetectConfig&isEnable=0&usr=admin&pwd=password"'
command_state: 'curl -k --silent "https://ipaddress:443/cgi-bin/CGIProxy.fcgi?cmd=getMotionDetectConfig&usr=admin&pwd=password" | grep -oP "(?<=isEnable>).*?(?=</isEnable>)"'
- Replace admin and password with an “Admin” privileged Foscam user
- Replace ipaddress with the local IP address of your Foscam
Actions
Available actions: reload.
Action command_line.reload
Reload all command_line entities.
This action takes no data attributes.
