Mijn Farmad Apotheek
The Mijn Farmad Apotheek integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you search the product catalog of your pharmacy and order medication for pickup from Home Assistant, using your Mijn Farmad Apotheek account. Mijn Farmad Apotheek is the online service of pharmacies connected to Farmad, a platform used by more than 1000 pharmacies in Flanders.
The integration adds no entities. You use it through its two actions, which run on demand: search the catalog of a pharmacy, and order one product for pickup.
Use cases
- Order medication that runs out on a regular schedule, without opening the app each time.
- Check the price and the stock of a product at your pharmacy before ordering.
- Place a new order when a supply you track in Home Assistant runs low.
- An account for the Mijn Farmad Apotheek app, registered at a pharmacy connected to Farmad. If you do not have an account yet, create one in the app or on the Farmad website.
- At least one pharmacy linked to your account in the app.
To add the Mijn Farmad Apotheek service to your Home Assistant instance, use this My button:
From the list, select Mijn Farmad Apotheek.
The password of your Mijn Farmad Apotheek account. It is only used to sign in, and is never stored.
Supported functionality
- The search action finds products in the catalog of a pharmacy by product name or CNK code, and returns up to 25 matches with price and stock.
- The order action places an order for one product at a pharmacy. Orders are paid at pickup.
- The Pharmacy field of both actions takes the APB number of the pharmacy, for example
343602. - Only users with administrator rights can run the order action.
List of actions
The Mijn Farmad Apotheek integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] provides the following actions. Each link below opens a dedicated page with examples, parameters, and a step-by-step UI walkthrough.
Order medication (
mijn_farmad_apotheek.order_medication) Places an order for one product at a Farmad pharmacy. The product is paid at pickup. -
Search medication (
mijn_farmad_apotheek.search_medication) Searches the catalog of a Farmad pharmacy by product name or CNK and returns up to 25 matching products.
Mijn Farmad Apotheek automation examples
Automation: order a product every month
This automation orders a known product on a monthly schedule, with a comment for the pharmacist. Create a calendar first, for example with the Local Calendar integration, and add an event that repeats on the first day of every month at 09:00. To find the CNK code of your product, use the Search medication action.
Trigger: Calendar event started
Calendar: Medication orders (
calendar.medication_orders)
Action: Mijn Farmad Apotheek: Order medication
- Product: 3093242
- Quantity: 2
- Pharmacy: 343602
- Comment: For monthly pickup
YAML example for ordering a product every month
alias: "Order a product every month"
description: "Orders two packages of a known product every month."
triggers:
- trigger: calendar.event_started
entity_id: calendar.medication_orders
actions:
- action: mijn_farmad_apotheek.order_medication
product: "3093242"
quantity: 2
apb: "343602"
comment: "For monthly pickup"
Data updates
The integration fetches nothing on a schedule. Each action contacts Farmad when you run it, so the search results show the current price and stock.
If Farmad rejects the stored session, the actions fail and Home Assistant asks you to sign in again.
Your password is only used to sign in, and it is never stored. The integration keeps only your email address and the tokens Farmad returns, and refreshes the tokens when needed.
Known limitations
Authentication
- The integration supports a single account per Home Assistant instance.
Ordering
- Each order holds one product. To order several products, call the order action once per product.
- Orders are paid at pickup. Paying online is not supported.
Language
- Product names in the search results and order confirmations are in Dutch.
The integration cannot be set up
Symptom: The setup form shows an error message
Setting up the integration fails with an error message.
Description
The setup form shows one of these errors:
- Failed to connect: Farmad could not be reached.
- Invalid authentication: the email address or the password is wrong.
Resolution
For a connection error, check that Home Assistant can reach the internet and try again. For an authentication error, check your credentials by signing in to the Mijn Farmad Apotheek app with them.
Actions fail because the pharmacy is not linked
Symptom: Your account has no access to the pharmacy
The action fails with the message that your account has no access to the pharmacy.
Description
The APB number in the Pharmacy field does not belong to a pharmacy linked to your account, for example because of a typo in the number.
Resolution
- Check the APB number and correct it if needed.
- If the number is correct, link the pharmacy in the Mijn Farmad Apotheek app, then run the action again.
Ordering fails because the draft basket is not empty
Symptom: The order fails because the draft basket is not empty
The order action fails with the message that the draft basket at the pharmacy still has products or a comment.
Description
The app keeps one draft basket per pharmacy. The order action refuses to order into a draft basket that already holds products or a comment, so it cannot overwrite a basket you started in the app. When an order fails before it reaches the pharmacy, the integration removes the product it added to the draft basket. When an order could not be confirmed, the product can stay in the draft basket, because the pharmacy may already have accepted the order.
Resolution
- Open the Mijn Farmad Apotheek app.
- When the draft basket holds the product of an order that could not be confirmed, check the order history first and contact the pharmacy if its status remains unclear.
- Once you know the order was not placed, submit the draft basket to place the order it holds, or clear it and run the action again to place a new order.
The order could not be confirmed
Symptom: The order could not be confirmed
The order action fails with the message that the order could not be confirmed.
Description
The order was sent, but the pharmacy did not confirm it before the connection dropped. The order may still have been placed.
Resolution
Check the order history in the Mijn Farmad Apotheek app before running the action again, so you do not order the same product twice.
Actions fail because the session expired
If your problem is not listed here, enable debug logging and check the logs:
- Select Mijn Farmad Apotheek.
- In the top right of the page, open the three dots
menu, and select Enable debug logging. - Run the action that gave you the error, then open the same menu, select Disable debug logging, and download the log file.
- Devices
- Hubs
- Services
- Integration entries
- To confirm, select Delete.
