ista EcoTrend
The ista EcoTrend integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] for Home Assistant allows you to import your monthly meter readings from the ista EcoTrend service.
About ista SE
ista SE is a company based in Germany that provides metering services for lessors and property owners. Its solutions are designed for rented or self-inhabited multi-party properties, enabling accurate measurement, assignment, and billing of heating and water consumption for renters or individual property owners.
How you can use this integration
The ista EcoTrend integration allows you to monitor your monthly heating and water usage in Home Assistant’s energy dashboard. View historical usage trends, track monthly consumption, and receive notifications when new data is available. This integration helps you stay informed about your household’s resource usage and make informed decisions about energy efficiency.
For new users
  1. If you received an activation code by mail, register at ecotrend.ista.com.
  2. If you did not receive an activation code after moving into a property with ista metering devices, contact your lessor or property manager.
For existing users
  1. Ensure you have an active ista EcoTrend account to set up the integration.
  2. During the setup process in Home Assistant, enter the email address and password associated with your ista EcoTrend account.
Note
The integration currently supports only the German EcoTrend service.
To add the ista EcoTrend integration to your Home Assistant instance, use this My button:
  • From the list, select ista EcoTrend.
Email
Enter the email address associated with your ista EcoTrend account to connect it to Home Assistant.
Password
Enter the password for your ista EcoTrend account to enable the connection with Home Assistant.
Sensors
The ista EcoTrend integration exposes the last monthly readings as sensors. It provides the following sensors:
  • Heating: readings from your heat cost allocators (measured in units)
  • Heating energy: estimated value in kWh
  • Heating costs: estimated costs in EUR
  • Hot water: consumption readings in m³
  • Hot water energy: estimated value in kWh
  • Hot water costs: estimated costs in EUR
  • Water: consumption readings in m³
  • Water costs: estimated costs in EUR
Not all values may be available in your ista EcoTrend account. Cost estimation is an optional service that has to be booked by your property manager or lessor. Therefore, the cost sensors are deactivated by default.
Long-term statistics
The ista EcoTrend integration allows you to import all your historical consumption readings from your ista EcoTrend account into long-term statistic entities. These entities can be displayed in your Home Assistant energy dashboard, providing a comprehensive view of your consumption data over time.
Identifying ista EcoTrend statistic entities
The statistic entities imported via this integration have a ista_ecotrend: prefix. This prefix helps you identify and distinguish these entities from other sensor statistics when setting up the long-term statistics in the energy dashboard.
Setting up long-term statistics in the energy dashboard
To set up the ista EcoTrend long-term statistics in your Home Assistant energy dashboard, follow these steps:
  • Access the energy configuration panel
  • Add heating energy usage
    • Go to Gas consumption.
    • Select Add gas source.
    • Choose your Heating energy entity (for example, ista_ecotrend:luxemburger_str_1_heating_energy).
    • For cost tracking, select the Use an entity tracking the total costs option.
    • Select the corresponding Heating costs entity (for example, ista_ecotrend:luxemburger_str_1_heating_cost).
  • Add hot water energy usage
    • To track hot water energy usage and costs (for example, ista_ecotrend:luxemburger_str_1_hot_water_energy and ista_ecotrend:luxemburger_str_1_hot_water_cost), repeat the above steps for your Hot water energy and Hot water costs entities.
  • Add hot water consumption
    • Go to Water consumption.
    • Select Add water source.
    • Choose the Hot water entity (for example, ista_ecotrend:luxemburger_str_1_hot_water).
    • Select the corresponding Hot water costs entity (for example, ista_ecotrend:luxemburger_str_1_hot_water_cost).
  • Add water consumption
    • To track cold water consumption and costs (for example, ista_ecotrend:luxemburger_str_1_water and ista_ecotrend:luxemburger_str_1_water_cost), repeat the above steps for your Water and Water costs entities.
Data updates
The integration checks for new readings every 24 hours.
Known limitations
  • The integration does not support two-factor authentication. To connect Home Assistant to ista Ecotrend, you must first disable two-factor authentication. To do this, navigate to Menü -> Benutzerkonto -> Zwei-Stufen-Authentifizierung and remove any registered authentication devices.
  • Sensor values reflect the meter readings from the previous month, as ista publishes new readings a few days after the end of the billing period. Long-term statistics are adjusted to display these readings as of the last day of the corresponding month.
Remove integration
This integration can be removed by following these steps:
  3. Next to the entry, select the three-dot menu. Then, select Delete.
