IRM KMI Weather Belgium
The Royal Meteorological Institute of Belgium integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] integrates the weather data from IRM KMI (meteo.be) with Home Assistant.
Although the provider is Belgian, the data is available for Belgium πŸ‡§πŸ‡ͺ, Luxembourg πŸ‡±πŸ‡Ί, and The Netherlands πŸ‡³πŸ‡±.
The data provided by this integration is retrieved from their mobile application.
To add the IRM KMI Weather Belgium service to your Home Assistant instance, use this My button:
  • From the list, select IRM KMI Weather Belgium.
Location
The location for which you want to get weather data.
Options
To define options for IRM KMI Weather Belgium, follow these steps:
  1. In Home Assistant, go to Settings > Devices & services.
  2. If multiple instances of IRM KMI Weather Belgium are configured, choose the instance you want to configure.
  3. On the card, select the cogwheel .
    • If the card does not have a cogwheel, the integration does not support options for this service.
    Screenshot showing the cogwheel icon on an integration card in the Settings > Devices & services page
  4. Edit the options, then select Submit to save the changes.
Language
Override the Home Assistant language for the textual weather forecast. Useful if your Home Assistant language is not supported by the Royal Meteorological Institute of Belgium.
Supported features
The integration provides a weather entity along with weather forecast services.
Limitations
  1. The weather provider sometimes uses two weather conditions for the same day (see below). When this is the case, only the first weather condition is taken into account in this integration.
    Example of two weather conditions
  2. The trends for 14 days are not shown.
  3. The provider only has data for Belgium, Luxembourg and The Netherlands.
Data updates
The integration pollsData polling is the process of querying a device or service at regular intervals to check for updates or retrieve data. By defining a custom polling interval, you can control how frequently your system checks for new data, which can help optimize performance and reduce unnecessary network traffic. [Learn more] weather data every 7 minutes by default.
When a poll cannot reach the API, the weather entity keeps showing the data from the last poll that succeeded. Once that poll is more than 17.5 minutes old, the next failed poll makes the entity unavailable, until a poll succeeds again.
      • Devices
      • Hubs
      • Services
      • Integration entries
  3. To confirm, select Delete.
