Flow-it
The Flow-it integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] lets you monitor and control your Flow-it ventilation system in Home Assistant.
Use case: You can control the fan speed, activate preset modes such as Auto or Boost, and automate your Flow-it ventilation system alongside other smart home devices.
Supported devices
The integration supports the following devices:
- Flow-it VMC ventilation systems equipped with Wi-Fi connectivity.
Before setting up the integration:
- Connect your Flow-it device to your local network.
- Locate the password and IP address (if setting up manually) on the physical LCD screen by navigating to Settings > Wi-Fi.
Automatic discovery via Zeroconf is recommended. When discovered automatically, Home Assistant configures the integration using the device hostname instead of its IP address, avoiding the need to set up a static DHCP lease in your router.
To add the Flow-it device to your Home Assistant instance, use this My button:
Flow-it can be auto-discovered by Home Assistant. If an instance was found, it will be shown as Discovered. You can then set it up right away.
From the list, select Flow-it.
The hostname or IP address of your Flow-it device on your local network. For example, 192.168.1.100 or vmc.local. You can find the IP address on the physical LCD screen under Settings > Wi-Fi.
Supported functionality
The Flow-it integration provides the following entities.
Fans
Fan
- Description: Controls the fan state, speed (levels 1 through 5), and preset modes.
Presets:
Auto,Boost.
Data updates
The Flow-it integration uses local push updates over a WebSocket connection to receive real-time status changes from the device, with periodic local polling every 60 seconds as a fallback.
menu. Then, select Delete.
