MQTT binary sensor
The MQTT binary sensor integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] uses an MQTT message received to set the binary sensor’s state to on, off or unknown.
The state will be updated only after a new message is published on state_topic matching payload_on, payload_off or None. If these messages are published with the retain flag set,
the binary sensor will receive an instant state update after subscription and Home Assistant will display the correct state on startup.
Otherwise, the initial state displayed in Home Assistant will be unknown.
Stateless devices such as buttons, remote controls etc are better represented by MQTT device triggers than by binary sensors.
The mqtt binary sensor platform optionally supports a list of availability topics to receive online and offline messages (birth and LWT messages) from the MQTT device. During normal operation, if the MQTT sensor device goes offline (i.e., publishes payload_not_available to an availability topic), Home Assistant will display the binary sensor as unavailable. If these messages are published with the retain flag set, the binary sensor will receive an instant update after subscription and Home Assistant will display the correct availability state of the binary sensor when Home Assistant starts up. If the retain flag is not set, Home Assistant will display the binary sensor as unavailable when Home Assistant starts up. If no availability topic is defined, Home Assistant will consider the MQTT device to be available and will display its state.
To use an MQTT binary sensor in your installation, add a MQTT device as a subentry, or add the following to your configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file.
After changing the configuration.yamlThe configuration.yaml file is the main configuration file for Home Assistant. It lists the integrations to be loaded and their specific configurations. In some cases, the configuration needs to be edited manually directly in the configuration.yaml file. Most integrations can be configured in the UI. [Learn more] file, restart Home Assistant to apply the changes.
mqtt:
- binary_sensor:
state_topic: "basement/window/contact"
Alternatively, a more advanced approach is to set it up via MQTT discovery.
A list of MQTT topics subscribed to receive availability (online/offline) updates. Must not be used together with availability_topic.
The payload that represents the available state.
The payload that represents the unavailable state.
When availability is configured, this controls the conditions needed to set the entity to available. Valid entries are all, any, and latest. If set to all, payload_available must be received on all configured availability topics before the entity is marked as online. If set to any, payload_available must be received on at least one configured availability topic before the entity is marked as online. If set to latest, the last payload_available or payload_not_available received on any configured availability topic controls the availability.
Defines a template to extract device’s availability from the availability_topic. To determine the devices’s availability result of this template will be compared to payload_available and payload_not_available.
The MQTT topic subscribed to receive birth and LWT messages from the MQTT device. If availability is not defined, the binary sensor will always be considered available and its state will be on, off or unknown. If availability is defined, the binary sensor will be considered as unavailable by default and the sensor’s initial state will be unavailable. Must not be used together with availability.
Use default_entity_id instead of name for automatic generation of the entity ID. For example, binary_sensor.foobar. When used without a unique_id, the entity ID will update during restart or reload if the entity ID is available. If the entity ID already exists, the entity ID will be created with a number at the end. When used with a unique_id, the default_entity_id is only used when the entity is added for the first time. When set, this overrides a user-customized entity ID if the entity was deleted and added again.
Information about the device this binary sensor is a part of to tie it into the device registry. Only works when unique_id is set. At least one of identifiers or connections must be present to identify the device.
A link to the webpage that can manage the configuration of this device. Can be either an http://, https:// or an internal homeassistant:// URL.
A list of connections of the device to the outside world as a list of tuples [connection_type, connection_identifier]. For example the MAC address of a network interface: "connections": [["mac", "02:5b:26:a8:dc:12"]].
A list of IDs that uniquely identify the device. For example a serial number.
Sets the class of the device, changing the device state and icon that is displayed on the frontend. The device_class can be null.
Flag which defines if the entity should be enabled when first added.
The encoding of the payloads received. Set to "" to disable decoding of incoming payload.
The category of the entity. When set, the entity category must be diagnostic for sensors.
If set, it defines the number of seconds after the sensor’s state expires if it’s not updated. After expiry, the sensor’s state becomes unavailable. By default, the sensor’s state never expires. Note that when a sensor’s value was sent retained to the MQTT broker, the last value sent will be replayed by the MQTT broker when Home Assistant restarts or is reloaded. As this could cause the sensor to become available with an expired state, it is not recommended to retain the sensor’s state payload at the MQTT broker. Home Assistant will store and restore the sensor’s state for you and calculate the remaining time to retain the sensor’s state before it becomes unavailable.
Sends update events (which results in update of state object’s last_changed) even if the sensor’s state hasn’t changed. Useful if you want to have meaningful value graphs in history or want to create an automation that triggers on every incoming state message (not only when the sensor’s new state is different to the current one).
Defines a template to extract the JSON dictionary from messages received on the json_attributes_topic. Usage example can be found in MQTT sensor documentation.
The MQTT topic subscribed to receive a JSON dictionary payload and then set as sensor attributes. Usage example can be found in MQTT sensor documentation.
The name of the binary sensor. Can be set to null if only the device name is relevant.
For sensors that only send on state updates (like PIRs), this variable sets a delay in seconds after which the sensor’s state will be updated back to off.
The string that represents the offline state.
The string that represents the off state. It will be compared to the message in the state_topic (see value_template for details)
The string that represents the on state. It will be compared to the message in the state_topic (see value_template for details)
Must be binary_sensor. Only allowed and required in MQTT auto discovery device messages.
The MQTT topic subscribed to receive sensor’s state. Valid states are OFF and ON. Custom OFF and ON values can be set with the payload_off and payload_on config options.
An ID that uniquely identifies this sensor. If two sensors have the same unique ID, Home Assistant will raise an exception. Required when used with device-based discovery.
Defines a template that returns a string to be compared to payload_on/payload_off or an empty string, in which case the MQTT message will be removed. Remove this option when payload_on and payload_off are sufficient to match your payloads (i.e no preprocessing of original message is required).
Examples
In this section, you will find some real-life examples of how to use this sensor.
Full configuration with JSON data
This is an example of a configuration where the state is extracted from a JSON formatted MQTT message.
To test, you can use the command line tool mosquitto_pub shipped with mosquitto or the mosquitto-clients package to send MQTT messages.
To set the state of the binary sensor manually:
mosquitto_pub -h 127.0.0.1 -t home-assistant/window/availability -m "online"
mosquitto_pub -h 127.0.0.1 -t home-assistant/window/contact -m '{"state":"ON"}'
mosquitto_pub -h 127.0.0.1 -t home-assistant/window/contact -m '{"state":"OFF"}'
The example below shows a full configuration for a binary sensor:
mqtt:
- binary_sensor:
name: "Window Contact Sensor"
state_topic: "bedroom/window/contact"
payload_on: "ON"
availability:
- topic: "bedroom/window/availability"
payload_available: "online"
payload_not_available: "offline"
qos: 0
device_class: opening
value_template: "{{ value_json.state }}"
Toggle the binary sensor each time a message is received on state_topic
mqtt:
- binary_sensor:
state_topic: "lab_button/cmnd/POWER"
value_template: "{%if is_state(entity_id,\"on\")-%}OFF{%-else-%}ON{%-endif%}"
Get the state of a device with ESPEasy
Assuming that you have flashed your ESP8266 unit with ESPEasy
As soon as the unit is online, you will get the state of the attached button.
home/bathroom/status Connected
home/bathroom/switch/button 1
The configuration will look like the example below:
mqtt:
- binary_sensor:
state_topic: "home/bathroom/switch/button"
payload_on: "1"
payload_off: "0"
