AnyList
The AnyList integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] connects your AnyList shopping lists to Home Assistant. Each AnyList shopping list is represented by a Home Assistant to-do list entity.
You can add, rename, complete, uncomplete, edit the description of, and remove shopping-list items from Home Assistant. Lists created, renamed, or removed in AnyList are reflected in Home Assistant without reconfiguring the integration.
You need an AnyList account with an email address and password.
To add the AnyList service to your Home Assistant instance, use this My button:
Configuration parameters
Email
The email address associated with your AnyList account.
Password
The password used to sign in to your AnyList account.
To-do lists
The integration creates one to-do list entity for each AnyList shopping list. The entity state is the number of incomplete items in that list.
The following item properties are synchronized:
  • Item name
  • Completed or incomplete status
  • Description
Changes made in Home Assistant are sent to AnyList immediately. Changes made in AnyList are delivered to Home Assistant through AnyList’s realtime connection.
Known limitations
Supported features
The integration exposes AnyList shopping lists only. Recipes and meal planning are not included.
Unofficial API
AnyList does not provide a public API. Changes to the AnyList service may temporarily affect the integration until it is updated.
Internet connection
An internet connection is required because all data is synchronized through AnyList’s cloud service.
This integration can be removed by following these steps:
      • Devices
      • Hubs
      • Services
      • Integration entries
  3. To confirm, select Delete.
