Serialize to JSON: to_json
The to_json filter converts a Python object (like a dictionary, list, string, or number) into a JSON-formatted string. This is the opposite of from_json, which parses a JSON string back into an object.
This is essential when you need to send structured data to external services. Many integrations like MQTT, REST, and webhooks expect JSON-formatted payloads. For example, you might build a dictionary with sensor data and convert it to JSON for an MQTT publish, or format a payload for a REST API call. The optional parameters let you control the output format: pretty_print adds indentation for readability, sort_keys orders the keys alphabetically, and ensure_ascii escapes non-ASCII characters.
Usage
{{ {"temperature": 21.5, "humidity": 45} | to_json }}
{"temperature":21.5,"humidity":45}
Function signature
value | to_json(
ensure_ascii: bool = False,
pretty_print: bool = False,
sort_keys: bool = False,
) -> str
Function parameters
If true, all non-ASCII characters are escaped in the output. Defaults to false, which allows Unicode characters to pass through unchanged.
If true, the output is formatted with indentation for readability. Useful for debugging or displaying structured data.
Pretty-printed output
Use pretty_print to format the JSON with indentation, making it easier to read in logs or on dashboards.
{"name": "Living Room", "temperature": 21.5}
| to_json(pretty_print=true)
"temperature": 21.5
Good to know
- The output has no spaces between keys and values by default, which is ideal for MQTT or API payloads but less readable. Turn on
pretty_printfor debugging. - Values that are not JSON-serializable (like datetime objects) raise an error. Convert them to strings or numbers first.
- Dictionary keys are preserved in their original order unless you set
sort_keys=true.
Try it yourself
More examples
Publish sensor data via MQTT
Build a JSON payload from sensor values and publish it to an MQTT topic.
action:
- action: mqtt.publish
topic: "home/sensors/living_room"
payload: >
"temperature": states("sensor.living_room_temperature") | float,
"humidity": states("sensor.living_room_humidity") | float,
"timestamp": now() | as_timestamp | int
} | to_json
Send data to a REST API
Format a dictionary as JSON for a RESTful notification or webhook.
action:
- action: rest_command.send_data
payload: >
"event": "door_opened",
"entity": "binary_sensor.front_door",
"state": states("binary_sensor.front_door")
} | to_json
Sort keys for consistent output
Use sort_keys when you need deterministic output, for example when comparing JSON strings.
{{ {"z": 1, "a": 2, "m": 3} | to_json(sort_keys=true) }}
{"a":2,"m":3,"z":1}
Still stuck?
Related template functions
Parse JSON string: from_json - Parses a JSON string into a Python object.
Merge dictionaries: combine - Merges multiple dictionaries into one.
