Human-readable duration: timedelta_string
The timedelta_string template function converts a timedelta object into a human-readable string like “2 hours” or “1 day 30 minutes”. Unlike time_since and time_until, which compute the duration from the current time to a given datetime, timedelta_string works directly on an already-computed timedelta. This makes it useful when you’ve already calculated a duration from a subtraction or from a sensor, and just want to display it nicely.
Negative timedeltas are formatted using their absolute value.
You can control the level of detail with the optional precision parameter, which determines how many time components (years, months, days, hours, minutes, seconds) to include.
Usage
{{ timedelta_string(trigger.to_state.last_changed - trigger.from_state.last_changed) }}
15 minutes
Function signature
timedelta_string(
    value: timedelta,
    precision: int = 1,
) -> str
Function parameters
value timedelta Required
A timedelta object to format as a human-readable string. If the value is not a timedelta, it is returned unmodified.
precision integer (Optional, default: 1)
The number of time components to include in the output, from 1 to 6. A precision of 1 might return “2 hours”, while a precision of 2 might return “2 hours 30 minutes”. Use 0 to include all components. Higher precision gives more detail.
Controlling precision
By default, timedelta_string returns only the largest time component. Increase the precision to include more detail.
{{ timedelta_string(timedelta(hours=2, minutes=30), 1) }}
3 hours
{{ timedelta_string(timedelta(hours=2, minutes=30), 2) }}
2 hours 30 minutes
{{ timedelta_string(timedelta(hours=1, minutes=54, seconds=33), 0) }}
1 hour 54 minutes 33 seconds
Good to know
  • If the input is not a timedelta, it is returned unmodified.
  • Negative timedeltas are formatted using their absolute value.
  • Durations shorter than one second return "0 seconds".
  • If you want to go the other direction — display how long ago a datetime was, or how long until a future one — use time_since or time_until instead.
Try it yourself
Ready to test this? Open Settings > Tools > Template, paste the example into the Template editor, and watch the result update on the right. Edit the values to see how the function adapts to your own entitiesAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more].
More examples
Show how long a door has been open
Display the elapsed time between two state changes in an automation.
{% set open_for = trigger.to_state.last_changed - trigger.from_state.last_changed %}
Open for {{ timedelta_string(open_for, 2) }}
Open for 15 minutes 30 seconds
Format a duration from a sensor
Some integrations expose durations as ISO 8601 strings. Parse and display them.
{% set duration = as_timedelta(states("sensor.runtime")) %}
Running for {{ timedelta_string(duration) }}
Running for 3 hours
Still stuck?
Tip
Related template functions
