Human-readable time remaining: time_until
The time_until template function returns a human-readable string describing how much time remains until a given datetimeA value representing a specific moment in time, including the date, time, and time zone. For example, 2026-04-05 14:30:00+00:00. Used for timestamps, scheduling, and time-based calculations. in the future. Give it a future datetime, and it returns something like “3 hours” or “2 days and 6 hours” instead of a raw number of seconds.
This is useful whenever you want to display a countdown or remaining time in a natural format. For example, showing how long until the next alarm goes off, displaying “arrives in 45 minutes” for a delivery, or reporting how much time is left on a timer. The function only works with datetimes in the future. For past datetimes, use time_since instead. You can control the level of detail with the optional precision parameter, which determines how many time components (years, months, days, hours, minutes, seconds) to include.
Usage
{{ time_until(as_datetime(states("sensor.next_alarm"))) }}
6 hours
Function signature
time_until(
    value: datetime,
    precision: int = 1,
) -> str
Function parameters
value datetime Required
A datetime object representing a point in the future. The function calculates the time remaining between now and this datetime.
precision integer (Optional, default: 1)
The number of time components to include in the output, from 1 to 6. A precision of 1 might return “6 hours”, while a precision of 2 might return “6 hours and 15 minutes”. Higher precision gives more detail.
Controlling precision
By default, time_until returns only the largest time component. Increase the precision to include more detail.
{{ time_until(as_datetime(states("sensor.next_alarm")), 1) }}
6 hours
{{ time_until(as_datetime(states("sensor.next_alarm")), 3) }}
6 hours, 15 minutes and 30 seconds
Good to know
  • Only works with datetimes in the future. For past datetimes, use time_since instead.
  • Durations shorter than one second return "0 seconds".
  • The input datetime must be time zone aware.
Try it yourself
More examples
Show time until next alarm
Display a countdown to the next alarm on your dashboard.
{{ "Alarm in " ~ time_until(as_datetime(states("sensor.next_alarm"))) }}
Alarm in 6 hours
Countdown to a scheduled event
Show how long until a calendar event starts, with more detail.
{% set event_time = as_datetime(states("sensor.next_appointment")) %}
Starts in {{ time_until(event_time, 2) }}
Starts in 2 hours and 30 minutes
Time remaining in an automation condition
Only run the rest of an automationAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more] if a scheduled event is less than 1 hour away. Combine time_until with a check on the remaining time using today_at and now.
condition:
  - condition: template
    value_template: >
        as_datetime(states("sensor.next_event")) - now()
        < timedelta(hours=1)
Still stuck?
Tip
Related template functions
