Test if string-like: string_like
The string_like test checks whether a value is a string or a string-like object. It returns true for strings, bytes, and bytearrays, and false for everything else, including lists, numbers, and dictionaries.
The built-in string test only matches text strings. Strings, bytes, and bytearrays are all iterable, so the iterable test returns true for them as well. Use string_like when you want to tell these text-like values apart from collections, such as lists and tuples.
Usage
{% if "hello" is string_like %}
It is string-like
{% endif %}
It is string-like
Function signature
Function parameters that have a = with a value after them are optional. If you leave them out, the default value shown is used automatically.
Function parameters without a = are usually required. A few optional parameters have no default value, so the signature shows them without a = as well. To check whether a parameter is required, look at the parameter list below the signature. Each parameter is marked as Required or Optional.
The most common optional parameter without a default value is default. The default parameter sets the value a function returns when the function can’t produce a result, for example, when float gets text that isn’t a number. If you leave out default, there is no fallback value, so most functions raise an error and the template fails. The parameter list of each function says what happens. If you set default, the function returns your value instead.
How to read a signature
Here is the signature of the round filter as an example:
round(
value: Any,
precision: int = 0,
method: str = "common",
default: Any,
) -> float | int | Any
roundis the name of the function. - Between the parentheses are the parameters. Each parameter has a name, followed by a colon and the type of value the parameter expects. The type only tells you what kind of value to pass. For
default: Any, you pass a value of any type, such as0or"unknown", not the wordAny. -
= 0and= "common"are default values. You can leave outprecisionandmethod, androunduses these default values. -
defaulthas no=, but the parameter list marksdefaultas optional. If you leave outdefaultandroundgets a value that isn’t a number,roundraises an error. -
->shows the type of value the function returns. - Inside a signature,
|means “or”. This function returns a decimal number, a whole number, or the value you passed asdefault.
round is a filter, so the first parameter, value, is the value before the |. For example, {{ 3.14159 | round(2) }} returns 3.14.
The types you’ll see most often:
str: text, such as"hello" -
int: a whole number, such as5 -
float: a decimal number, such as3.14 -
bool:trueorfalse -
list: a list of values, such as[1, 2, 3].list[str]is a list of texts. -
dict: a set of keys and values, such as{"name": "Kitchen"} -
datetimeandtimedelta: a date and time, and a duration. For details, refer to Dates and times. -
None: no value -
Any: any type of value
Some signatures use special forms:
*argsmeans you can pass any number of values, separated by commas. For example,average(1, 2, 3). -
value | name(...)means the function is a filter. The value before the|is passed to the filter as its first parameter. Some filter signatures, like theroundexample, show this value as the first parameter between the parentheses instead.
string_like(
value: Any,
) -> bool
Function parameters
The following parameters can be provided to this test.
Good to know
- Strings, bytes, and bytearrays pass. The built-in
stringtest only passes for strings. - Numbers, lists, tuples, sets, and dictionaries do not pass.
- To find collections only, combine this test with
iterable:value is iterable and value is not string_like.
Try it yourself
Ready to test this? Open Settings > Tools > Template, paste the example into the Template editor, and watch the result update on the right. Edit the values to see how the function adapts to your own entitiesAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more].
More examples
Distinguish text-like values from other values
Check whether a value is a string or bytes rather than a list or number.
{{ "abc" is string_like }}
{{ ("616263" | from_hex) is string_like }}
{{ [1, 2, 3] is string_like }}
{{ 42 is string_like }}
true
true
false
false
Find collections but not text
Strings are iterable, so iterable alone also matches them. Exclude them with is not string_like.
{{ "abc" is iterable and "abc" is not string_like }}
{{ [1, 2, 3] is iterable and [1, 2, 3] is not string_like }}
false
true
Still stuck?
Related template functions
Convert to string: string - Converts a value to its string representation.
Test if iterable: iterable - Tests whether a value is iterable.
Test if sequence: sequence - Tests whether a value is a sequence (list, tuple, string, or dictionary).
Get the type of a value: typeof - Returns the type name of a value as a string.
