Get translated state: state_translated
The state_translated template function returns the state of an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] translated into the language configured in Home Assistant. While states returns the raw English state value (like on, off, heating), this function returns the localized version shown in the interface.
This is useful when you want to include entity states in notificationsYou can use notifications to send messages, pictures, and more, to devices. [Learn more] or dashboard text that should match your configured language. For example, if your Home Assistant is set to German, state_translated("climate.living_room") might return “Heizen” instead of heating.
Usage
{{ state_translated("climate.living_room") }}
Heating
Function signature
state_translated(
    entity_id: str,
) -> str
Function parameters
entity_id string Required
The entity ID to get the translated state from. Returns the state in your configured language. Returns unknown if the entity does not exist.
Good to know
  • The returned text depends on the language configured in Home Assistant, so comparing the result against a fixed English word like "heating" will fail once the language changes. Use states for comparisons and reserve state_translated for display.
  • Translations come from the entity’s integration. Entities without translated states fall back to the raw state value.
Try it yourself
More examples
Use in a notification
Send a notification with the climate state in your configured language.
action:
  - action: notify.mobile
      message: >
        The living room climate is
Still stuck?
Tip
Related template functions
