Get translated attribute value: state_attr_translated
The state_attr_translated template function returns the value of an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more]’s attribute translated into your configured language. While state_attr returns the raw attribute value, this function returns the localized version shown in the interface.
This is useful when you display attribute values that have been translated by integrationsIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more], such as HVAC modes, fan modes, or preset names. For example, if your Home Assistant is set to French, state_attr_translated("climate.living_room", "hvac_action") might return “Chauffage” instead of heating.
Usage
{{ state_attr_translated("climate.living_room", "hvac_action") }}
Heating
Function signature
    entity_id: str,
    attribute: str,
) -> Any
Function parameters
entity_id string Required
The entity ID to get the translated attribute from.
attribute string Required
The name of the attribute to retrieve. Returns the translated value if a translation is available, otherwise returns the raw value. Returns None if the entity or attribute does not exist.
Good to know
  • Returns None when the entity or attribute does not exist.
  • Only attributes that integrations provide translations for are localized. Unsupported attributes fall back to the raw value.
  • The output depends on the Home Assistant user language, not a fixed locale.
Try it yourself
More examples
Show the translated HVAC action
Display the current action of a climate entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] in your language.
The heater is currently: {{ state_attr_translated(
The heater is currently: Heating
Show the translated fan mode
Show a media player’s or climate device’s mode in a friendly, localized way.
Fan mode: {{ state_attr_translated("climate.bedroom", "fan_mode") }}
Fan mode: Automatic
Build a localized status message
Combine the translated state with the translated attribute to build a status line in your language.
{% set entity = "climate.living_room" %}
The thermostat is {{ state_translated(entity) }} and {{
  state_attr_translated(entity, "preset_mode") | lower }}.
The thermostat is Heat and eco.
Still stuck?
Tip
Related template functions
