Test if set: set
The set test checks whether a value is a set, an unordered collection of unique values. It returns true for sets and false for everything else, including lists, tuples, dictionaries, and strings.
Jinja has no built-in test for sets, and templates have no literal syntax for them. You create a set with the set function, and some values that Home Assistant returns are sets, for example the identifiers and connections of a device. This test lets you check the type before you use set-specific features like removing duplicates or comparing collections.
Usage
As a test
{% if set([1, 2, 3]) is set %}
  It is a set
{% endif %}
It is a set
Function signature
Function parameters that have a = with a value after them are optional. If you leave them out, the default value shown is used automatically.
Function parameters without a = are usually required. A few optional parameters have no default value, so the signature shows them without a = as well. To check whether a parameter is required, look at the parameter list below the signature. Each parameter is marked as Required or Optional.
The most common optional parameter without a default value is default. The default parameter sets the value a function returns when the function can’t produce a result, for example, when float gets text that isn’t a number. If you leave out default, there is no fallback value, so most functions raise an error and the template fails. The parameter list of each function says what happens. If you set default, the function returns your value instead.
How to read a signature
Here is the signature of the round filter as an example:
round(
    value: Any,
    precision: int = 0,
    method: str = "common",
    default: Any,
) -> float | int | Any
  • round is the name of the function.
  • Between the parentheses are the parameters. Each parameter has a name, followed by a colon and the type of value the parameter expects. The type only tells you what kind of value to pass. For default: Any, you pass a value of any type, such as 0 or "unknown", not the word Any.
  • = 0 and = "common" are default values. You can leave out precision and method, and round uses these default values.
  • default has no =, but the parameter list marks default as optional. If you leave out default and round gets a value that isn’t a number, round raises an error.
  • -> shows the type of value the function returns.
  • Inside a signature, | means “or”. This function returns a decimal number, a whole number, or the value you passed as default.
round is a filter, so the first parameter, value, is the value before the |. For example, {{ 3.14159 | round(2) }} returns 3.14.
The types you’ll see most often:
  • str: text, such as "hello"
  • int: a whole number, such as 5
  • float: a decimal number, such as 3.14
  • bool: true or false
  • list: a list of values, such as [1, 2, 3]. list[str] is a list of texts.
  • dict: a set of keys and values, such as {"name": "Kitchen"}
  • datetime and timedelta: a date and time, and a duration. For details, refer to Dates and times.
  • None: no value
  • Any: any type of value
Some signatures use special forms:
  • *args means you can pass any number of values, separated by commas. For example, average(1, 2, 3).
  • value | name(...) means the function is a filter. The value before the | is passed to the filter as its first parameter. Some filter signatures, like the round example, show this value as the first parameter between the parentheses instead.
set(
    value: Any,
) -> bool
Function parameters
The following parameters can be provided to this test.
value any Required
The value to test. Returns true if the value is a set.
Good to know
  • Only real sets pass. Lists, tuples, dictionaries, and strings do not. To check the type of those values, use typeof.
  • A set has no fixed order, and it holds each value only once.
  • To convert a value to a set, use the set function.
Try it yourself
Ready to test this? Open Settings > Tools > Template, paste the example into the Template editor, and watch the result update on the right. Edit the values to see how the function adapts to your own entitiesAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more].
More examples
Distinguish a set from other values
Check whether a value is a set rather than a list, tuple, or string.
{{ set([1, 2, 2, 3]) is set }}
{{ [1, 2, 3] is set }}
{{ (1, 2, 3) is set }}
{{ "abc" is set }}
true
false
false
false
Convert to a set only when needed
Convert a list to a set to remove duplicates, but leave existing sets as they are.
{% set values = [1, 2, 2, 3] %}
{% set unique = values if values is set else set(values) %}
{{ unique | count }}
Result (integerA whole number without decimal places, like 1, 42, or -5. Used for counts, indices, and whole values.)
3
Still stuck?
Tip
Related template functions
