Get entities with a label: label_entities
The label_entities template function returns a list of entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] IDs that have a specific labelLabels in Home Assistant allow grouping elements irrespective of their physical location or type. Labels can be assigned to areas, devices, entities, automations, scenes, scripts, and helpers. Labels can be used in automations and scripts as a target for actions. Labels can also be used to filter data. [Learn more] assigned. You can specify the label by its name or by its internal ID. This gives you all entities tagged with that label.
This is useful when you want to act on a group of entities that share a common label, regardless of which areaAn area in Home Assistant is a logical grouping of devices and entities that are meant to match areas (or rooms) in the physical world: your home. For example, the living room area groups devices and entities in your living room. [Learn more] or deviceA device is a model representing a physical or logical unit that contains entities. they belong to. For example, if you label certain sensors as “Critical”, you could use label_entities to monitor all of them at once, or if you label energy-related entities as “Energy Monitoring”, you could build a dashboard that automatically includes every labeled entity. As you add or remove labels from entities, the list automatically updates, so your automationsAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more] and templatesA template is an automation definition that can include variables for the action or data from the trigger values. This allows automations to generate dynamic actions. [Learn more] always stay current.
Automation actions can target entities by label through the visual editor, no template needed. Reach for label_entities() when you need to loop over or filter the entities inside a template expression.
Usage
{{ label_entities("Critical") }}
"sensor.living_room_temperature",
"binary_sensor.front_door",
"binary_sensor.smoke_detector",
Function signature
label_entities(
label_id_or_name: str,
) -> list[str]
Function parameters
The label name or ID to look up. Returns the entity IDs that have this label assigned. You can find labels in Settings > Areas, labels & zones.
Good to know
- Only returns entities with the label assigned directly. Labels applied to devices or areas do not roll up to their entities.
- Returns an empty list when the label does not match any entities.
Try it yourself
More examples
Count entities with a specific label
Find out how many entities are tagged with a given label.
{{ label_entities("Critical") | count }}
3
Check if any critical entity is unavailable
Monitor all entities with a specific label and report if any of them are unavailable.
| select("is_state", "unavailable")
| list
| count > 0
false
List the states of all labeled entities
Display the current state of every entity that has a given label.
{% for entity_id in label_entities("Energy Monitoring") %}
{{ state_attr(entity_id, "friendly_name") }}: {{ states(entity_id) }}
{% endfor %}
Living Room Power: 120
Kitchen Power: 85
Dryer Power: 2400
Sum up energy usage from labeled entities
Calculate the total value across all entities with a specific label. This is useful for energy monitoring dashboards.
| map("states")
| map("float", default=0)
| sum
2605.0
Still stuck?
Related template functions
Get areas with a label: label_areas - Returns a list of area IDs that have a specific label assigned.
Get devices with a label: label_devices - Returns a list of device IDs that have a specific label assigned.
Get all labels: labels - Returns a list of all label IDs, or the labels assigned to a specific entity, device, or area.
Get label ID: label_id - Returns the label ID for a given label name.
Get label name: label_name - Returns the friendly name of a label from its ID.
