Get areas with a label: label_areas
The label_areas template function returns a list of areaAn area in Home Assistant is a logical grouping of devices and entities that are meant to match areas (or rooms) in the physical world: your home. For example, the living room area groups devices and entities in your living room. [Learn more] IDs that have a specific labelLabels in Home Assistant allow grouping elements irrespective of their physical location or type. Labels can be assigned to areas, devices, entities, automations, scenes, scripts, and helpers. Labels can be used in automations and scripts as a target for actions. Labels can also be used to filter data. [Learn more] assigned. You can specify the label by its name or by its internal ID. This gives you all areas tagged with that label.
This is useful when you organize your areas using labels and want to act on groups of rooms. For example, if you label certain areas as “Outdoor”, you could use label_areas to find all outdoor areas and then turn off their lights at night, or check the temperature in all rooms labeled “Heated”. As you add or remove labels from areas, the list automatically updates, so your automationsAutomations in Home Assistant allow you to automatically respond to things that happen in and around your home. [Learn more] and templatesA template is an automation definition that can include variables for the action or data from the trigger values. This allows automations to generate dynamic actions. [Learn more] always stay in sync.
Usage
{{ label_areas("Outdoor") }}
  "patio",
  "garden",
  "driveway",
Function signature
label_areas(
    label_id_or_name: str,
) -> list[str]
Function parameters
label_id_or_name string Required
The label name or ID to look up. Returns the area IDs that have this label assigned. You can find labels in Settings > Areas, labels & zones.
Good to know
  • Returns an empty list when the label does not exist or no areas carry it.
  • Accepts either the label name or the label ID, matching by name first.
Try it yourself
More examples
Count how many areas have a label
Find out how many areas are tagged with a specific label.
{{ label_areas("Outdoor") | count }}
Result (integerA whole number without decimal places, like 1, 42, or -5. Used for counts, indices, and whole values.)
3
List area names with a specific label
Get the friendly names of all areas that have a given label by combining label_areas with area_name.
  | map("area_name")
  | join(", ")
Patio, Garden, Driveway
Turn off lights in all areas with a label
Use in an automation to find all areas tagged with a label and act on their entities. This example collects all light entities from areas labeled “Outdoor”.
{% for area_id in label_areas("Outdoor") %}
  {% for entity_id in area_entities(area_id)
    | select("match", "light.") %}
    {{ entity_id }}
  {% endfor %}
{% endfor %}
Still stuck?
Tip
Related template functions
