Test if entity is hidden: is_hidden_entity
The is_hidden_entity template function checks whether an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] has been marked as hidden in the entity registry. It returns true if the entity exists and is hidden, and false otherwise.
Hidden entities are ones you have chosen to hide from the default user interface. They still exist and still track state, but they are not shown on dashboards by default. This function is useful when you are looping over entities in an areaAn area in Home Assistant is a logical grouping of devices and entities that are meant to match areas (or rooms) in the physical world: your home. For example, the living room area groups devices and entities in your living room. [Learn more] or domainEach integration in Home Assistant has a unique identifier: The domain. It is often shown as the first part (before the dot) of entity IDs. and want to skip the ones that have been hidden. For example, you might want to count how many visible sensors are in a room, or build a dynamic dashboard card that only lists entities you have not hidden.
Usage
{{ is_hidden_entity("sensor.internal_diagnostics") }}
true
Function signature
is_hidden_entity(
entity_id: str,
) -> bool
Function parameters
Good to know
- Returns
falsefor entities that do not exist in the registry, not just for visible ones. - This checks the registry “hidden” flag only. It does not detect entities filtered out by dashboard cards or custom visibility.
Try it yourself
More examples
Count visible entities in an area
Count the number of entities in an areaAn area in Home Assistant is a logical grouping of devices and entities that are meant to match areas (or rooms) in the physical world: your home. For example, the living room area groups devices and entities in your living room. [Learn more] that are not hidden, so you know how many are actually shown on the dashboard.
area_entities("Living Room")
| reject("is_hidden_entity")
| list
| count
8
Filter out hidden entities from a list
Build a list of only the visible sensor entities in the kitchen.
{% for entity_id in area_entities("Kitchen")
| select("match", "sensor.")
| reject("is_hidden_entity") %}
{{ entity_id }}
{% endfor %}
Still stuck?
Related template functions
Check if entity has a value: has_value - Tests if an entity exists and has a valid state (not unavailable or unknown).
Test entity state: is_state - Tests if an entity is in a specific state.
Get entity name: entity_name - Gets the friendly name of an entity from its entity ID.
Get entities in an area: area_entities - Returns a list of entity IDs associated with a given area.
