Check if entity has a value: has_value
The has_value template function checks whether an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] exists and has a meaningful state. It returns false if the entity doesn’t exist, is unavailable, or is unknown. Otherwise it returns true.
This is essential for building robust templatesA template is an automation definition that can include variables for the action or data from the trigger values. This allows automations to generate dynamic actions. [Learn more] that don’t break when a sensorSensors return information about a thing, for instance the level of water in a tank. [Learn more] goes offline or hasn’t reported yet. Sensors can temporarily become unavailable (for example, when a battery-powered deviceA device is a model representing a physical or logical unit that contains entities. goes to sleep) or unknown (during Home Assistant startup). By checking with has_value first, you can avoid errors in calculations or show a fallback message instead of displaying confusing values.
Tip
Automation triggers and conditions let you require an entity to have a valid state through the visual editor. Reach for has_value() when you need the check inside a template expression.
Usage
{{ has_value("sensor.temperature") }}
true
Function signature
has_value(
    entity_id: str,
) -> bool
Function parameters
entity_id string Required
The entity ID to check. Returns true if the entity exists and its state is not unavailable or unknown.
Tip
You can check if an entity is unavailable or unknown by looking it up in Developer Tools > States. The state column shows the current value.
Good to know
  • Returns false for missing entities, so use this before reading a state with states to avoid chasing unknown or unavailable downstream.
  • Treats both unavailable and unknown the same. If you only want to exclude one, compare to the specific state with is_state.
Try it yourself
More examples
Safely read a sensor value with a fallback
Only use the sensor value if it’s available, otherwise show a default message.
{% if has_value("sensor.outdoor_temperature") %}
  It's {{ states("sensor.outdoor_temperature") }}°C outside
{% else %}
  Temperature sensor is not available
{% endif %}
It's 18.5°C outside
Guard a calculation
Prevent errors by checking that a sensor has a value before doing math with it.
{% if has_value("sensor.power_usage") %}
  {{ states("sensor.power_usage") | float * 0.25 }}
{% else %}
  0
{% endif %}
Result (floatA number that can have decimal places, like 21.5 or 3.14. Used for temperatures, percentages, and other measurements that need precision.)
62.5
Still stuck?
Tip
Related template functions
