Get entity name: entity_name
The entity_name template function returns the friendly name of an entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] given its entity ID. It looks up the name from the entityAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more] registry first, falling back to the state object if the entity is not registered. If the entity does not exist at all, it returns None.
This is helpful whenever you want to display a human-readable name instead of a raw entity ID. For example, you might want to build a notificationYou can use notifications to send messages, pictures, and more, to devices. [Learn more] that says “The Living Room Light is on” instead of “light.living_room is on”. It is also useful when looping over a list of entity IDs and you need to present their names to a user in a readable format.
Usage
{{ entity_name("sensor.living_room_temperature") }}
Living Room Temperature
Function signature
entity_name(
    entity_id: str,
) -> str | None
Function parameters
entity_id string Required
The entity ID to look up. Returns the friendly name as a string, or None if the entity does not exist.
Good to know
  • Returns None when the entity does not exist. Chain with | default(value) for a fallback.
  • Uses the friendly name from the entity registry first, then falls back to the state object’s friendly name.
Try it yourself
More examples
Use entity names in a notification
Send a notificationYou can use notifications to send messages, pictures, and more, to devices. [Learn more] with the friendly name of a sensorSensors return information about a thing, for instance the level of water in a tank. [Learn more] instead of its entity ID.
action:
  - action: notify.mobile
      message: >
        {{ entity_name("binary_sensor.front_door") }} is
        {{ states("binary_sensor.front_door") }}
List names of all lights that are on
Loop through all light entities and display the friendly name of each one that is currently on.
{% for light in states.light | selectattr("state", "eq", "on") %}
  {{ entity_name(light.entity_id) }}
{% endfor %}
Still stuck?
Tip
Related template functions
