Test if datetime: datetime
The datetime test checks whether a value is a datetime object, a specific moment in time with a date and a time. It returns true for datetime objects and false for everything else, including date-and-time strings, UNIX timestamps, and date-only values.
Many sensors and attributes provide dates and times as plain text or numbers. This test lets you check whether a value is already a datetime before you compare it, calculate with it, or convert it with as_datetime.
Usage
{% if now() is datetime %}
It is a datetime
{% endif %}
It is a datetime
Function signature
Function parameters that have a = with a value after them are optional. If you leave them out, the default value shown is used automatically.
Function parameters without a = are usually required. A few optional parameters have no default value, so the signature shows them without a = as well. To check whether a parameter is required, look at the parameter list below the signature. Each parameter is marked as Required or Optional.
The most common optional parameter without a default value is default. The default parameter sets the value a function returns when the function can’t produce a result, for example, when float gets text that isn’t a number. If you leave out default, there is no fallback value, so most functions raise an error and the template fails. The parameter list of each function says what happens. If you set default, the function returns your value instead.
How to read a signature
Here is the signature of the round filter as an example:
round(
value: Any,
precision: int = 0,
method: str = "common",
default: Any,
) -> float | int | Any
roundis the name of the function. - Between the parentheses are the parameters. Each parameter has a name, followed by a colon and the type of value the parameter expects. The type only tells you what kind of value to pass. For
default: Any, you pass a value of any type, such as0or"unknown", not the wordAny. -
= 0and= "common"are default values. You can leave outprecisionandmethod, androunduses these default values. -
defaulthas no=, but the parameter list marksdefaultas optional. If you leave outdefaultandroundgets a value that isn’t a number,roundraises an error. -
->shows the type of value the function returns. - Inside a signature,
|means “or”. This function returns a decimal number, a whole number, or the value you passed asdefault.
round is a filter, so the first parameter, value, is the value before the |. For example, {{ 3.14159 | round(2) }} returns 3.14.
The types you’ll see most often:
str: text, such as"hello" -
int: a whole number, such as5 -
float: a decimal number, such as3.14 -
bool:trueorfalse -
list: a list of values, such as[1, 2, 3].list[str]is a list of texts. -
dict: a set of keys and values, such as{"name": "Kitchen"} -
datetimeandtimedelta: a date and time, and a duration. For details, refer to Dates and times. -
None: no value -
Any: any type of value
Some signatures use special forms:
*argsmeans you can pass any number of values, separated by commas. For example,average(1, 2, 3). -
value | name(...)means the function is a filter. The value before the|is passed to the filter as its first parameter. Some filter signatures, like theroundexample, show this value as the first parameter between the parentheses instead.
datetime(
value: Any,
) -> bool
Function parameters
The following parameters can be provided to this test.
Good to know
- Only real datetime objects pass. Strings like
"2024-03-15T14:30:00+01:00", UNIX timestamps, and date-only values do not. - Datetimes with and without a time zone both pass.
- To convert a string or a UNIX timestamp, use
as_datetime. It returnsNonefor invalid text, andNonedoes not pass this test.
Try it yourself
Ready to test this? Open Settings > Tools > Template, paste the example into the Template editor, and watch the result update on the right. Edit the values to see how the function adapts to your own entitiesAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more].
More examples
Distinguish a datetime from other values
Check whether a value is a datetime rather than a string or a number.
{{ now() is datetime }}
{{ "2024-03-15T14:30:00+01:00" is datetime }}
{{ as_datetime("2024-03-15T14:30:00+01:00") is datetime }}
{{ 1710510600 is datetime }}
true
false
true
false
Convert to a datetime only when needed
Convert a value with as_datetime only if it is not already a datetime.
{% set value = "2024-03-15T14:30:00+01:00" %}
{% set moment = value if value is datetime else as_datetime(value) %}
{{ moment }}
2024-03-15 14:30:00+01:00
Check that a conversion worked
as_datetime returns None for text it cannot parse, so test the result before you use it.
{% set moment = as_datetime("not a date") %}
{% if moment is datetime %}
Year: {{ moment.year }}
{% else %}
Not a valid date
{% endif %}
Not a valid date
Still stuck?
Related template functions
Convert to datetime: as_datetime - Converts a string or timestamp to a datetime object.
Convert to local time zone: as_local - Converts a datetime object to your local time zone.
Current local date and time: now - Returns the current date and time in your local time zone.
Get the type of a value: typeof - Returns the type name of a value as a string.
