Get config entry attribute: config_entry_attr
The config_entry_attr template function returns a specific attribute from a config entry, identified by its config entry ID. You can retrieve attributes like domain, title, state, source, disabled_by, and pref_disable_polling. It returns None if the config entry does not exist.
This is useful for inspecting the configuration behind your entitiesAn entity represents a sensor, actor, or function in Home Assistant. Entities are used to monitor physical properties or to control other entities. An entity is usually part of a device or a service. [Learn more]. For example, you might want to check if a config entry is still loaded and working, find out which integrationIntegrations connect and integrate Home Assistant with your devices, services, and more. [Learn more] domain it belongs to, or display the title of the config entry in a notificationYou can use notifications to send messages, pictures, and more, to devices. [Learn more]. Combined with config_entry_id, you can trace any entity back to its config entry and read details about it.
Usage
{{ config_entry_attr("01234567890abcdef01234567890abcd", "title") }}
Living Room Hue Bridge
Function signature
config_entry_attr(
    config_entry_id: str,
    attr_name: str,
) -> Any
Function parameters
config_entry_id string Required
The config entry ID to look up. You can get this from config_entry_id.
attr_name string Required
The attribute to retrieve. Must be one of: domain, title, state, source, disabled_by, or pref_disable_polling.
Available attributes
The following attributes can be retrieved from a config entry:
  • domain: The integration domain (for example, hue, zwave_js).
  • title: The user-defined title of the config entry.
  • state: The current state of the config entry (for example, loaded, setup_error, not_loaded).
  • source: How the config entry was created (for example, user, discovery).
  • disabled_by: Why the config entry is disabled, or None if it is not disabled.
  • pref_disable_polling: Whether polling has been disabled for this config entry.
Good to know
  • Returns None when the config entry does not exist or when the attribute name is not one of the supported ones.
  • Only the fixed attribute names listed above are allowed. Arbitrary field names are rejected.
  • The input is the config entry ID, not an entity ID. Resolve from an entity with config_entry_id first.
Try it yourself
More examples
Check the state of a config entry from an entity
Look up the config entry behind an entity and check its state to see if the integration is running.
{% set entry_id = config_entry_id("light.living_room") %}
{{ config_entry_attr(entry_id, "state") }}
loaded
Get the integration domain for an entity
Find out which integration is responsible for a specific entity.
{% set entry_id = config_entry_id("sensor.power_meter") %}
{{ config_entry_attr(entry_id, "domain") }}
shelly
Check if a config entry was discovered automatically
Determine whether a config entry was set up manually or discovered automatically.
{% set entry_id = config_entry_id("light.bedroom") %}
{{ config_entry_attr(entry_id, "source") }}
discovery
Still stuck?
Tip
Related template functions
